Roll Cage
Originally posted by value
CUSCO and Safety 21 have 4,5,6,7,8 point setups.
Josh
Originally posted by 90GSX-03EVO
Tracks won't let you run if you are faster than the 11 second barrier without a cage. Oh, and I have a lot of plans for the car that I don't want to discuss right now. However, my goal is to have a full interior Evo with a fully functional roll cage. Even if it means that my rear seats are essentially useless for passengers, I still want to keep them in place. Im just subtly going for a record or two with this car. I prefer to stay silent about the project until it is complete.....No, it will NOT be an all out drag race car that never turns left and right.
Thanks for the info about TAD. I have talked to them before, but they are a little far away from me, by about 4,000 miles or so. Maybe they could fab. one and then ship it to me for on-site installment. Who knows, we'll see.
Josh
Josh
Anyway, I doubt TAD will do a prefab thing, that's not their thing. Good luck with the roll cage and have fun picking the dents out of your skull.
If you're going to have a cage built, have it built for a particular purpose - a roll cage that works for drag racing will not necessarily be safe for rally or road racing. The types of impact each cage is designed to absorb is different - ie you don't worry about center-punching a tree in a drag car but that's pretty common in rally. All cages are designed to be used in conjuction with other safety equipment - helmets and harnesses. If you get into an accident on the street in a car with a roll cage you run a very real risk of having your head bounce off the cage.
Bolt in. Here's more info:
CUSCO all powdercoated blue prices are approx retail @ 111 rate:
4pt $342 23.14 lbs
5pt $495 28.21 lbs
6pt $612 41lbs
7pt $765 46lbs
8pt $945 51.14lbs
Padding is avail. in assorted colors
Safety 21
4pt $270.27 28.66 lb
5pt $360.36 35.27 lb
6pt $513.51 52.9 lb
7pt $603.60 59.52 lb
8pt $693.69 66.13 lb
4pt $342 23.14 lbs
5pt $495 28.21 lbs
6pt $612 41lbs
7pt $765 46lbs
8pt $945 51.14lbs
Safety 21
6pt $513.51 52.9 lb
sorry if this question is off topic,
i would like to ask if i want to equiped 4 or 5 point seat belt harness, do we require a roll cage or roll bar, is there any way to put it on stock EVO VIII?
did anyone has pic of his/her EVO with aftermaket seat belt on EVO VIII?
appreciated!
-Ben
appreciated!
-Ben
Originally posted by Turboholic
equiped 4 or 5 point seat belt harness, do we require a roll cage or roll bar?
Josh
The tether strap hook for a child seat is another good anchor point. If it will hold a child seat, it should hold you. Use a caribiner or a link for chain that has the screw engagement. That is if you don't install a cage. Great spot if you are doing track events that don't require a roll bar or autocross.
If you get a rollbar/cage, post some pics.
Jason
Jason
Why would you need a harness if you had no roll cage?
if you flip, you will be crushed, since you won't be able to move to the left/right like you can with a 3 point DOT approved seatbelt.
The harness allows you to sit in the crappy Lancer seats without bracing yourself with the wheel or your legs. The cars in the US market will support the weight of the vehicle in the event of a rollover as I believe that is mandated by our government. I would not recommend road racing or rallying without a cage, nor is it usually sanctioned, but for an autocross or HPDE, it(the rollcage) may not be required.
It would definitely be safer with a cage, don't misread my input. Stock belts lack the ability to hold you securely during autocross. Harnesses allow you to drive instead of brace.
Jason
Jason
and I second the comment about the safety in a car with a harness and no roll cage. Although the danger only applies to rolling such a car. I use the racing harness for autocrossing, for the same reason as Jason... holding my body in place so I can focus on steering. Otherwise, I tuck the seatbelt under my seat and use the stock one (easier to reach the AC and radio controls anyway
Originally posted by urbanknight
The normal seatbelt anchors use 17mm socket while the child seat uses I believe 14mm. The hole in my Schroth harness bracket was so large I'd need a fender washer just to know the bolt won't slip through it (slight exaggeration, but the bolt almost does slip through the bracket). So anyway, that got me thinking, if it has a smaller bolt and is meant to hold a child under 70 pounds, maybe it isn't such a good idea to hold a 150 pound driver racing.
Jason
Originally posted by MrBubbler
dam so what would be the best setup and still be streetable
Jason
