My brake cooling solution idea
Old Jan 14, 2008 | 07:21 PM
sponge bob's Avatar
Originally Posted by SmikeEvo
How did you attach the hose to the brakes?
I had some hub mounted nozzles like SmikeEvo uses but I sold them to someone. I’m using 3” cooling hose so I’m attempting to fabricate my own nozzles that accommodate the larger hose. In the end it all funnels down to the same rather small opening between the caliper and the hub so I’m not sure if it will make any difference.
Old Jan 14, 2008 | 07:22 PM
nils's Avatar
love the idea... let us know if it gets enough air to the brakes.
n
Old Jan 14, 2008 | 07:51 PM
GTLocke13's Avatar
Originally Posted by nothere
I like the idea, but I don't think the pressure is anywhere near what it is on the face of the bumper.
You might be very surprised if you actually tested it. I'm not saying I have, but the whole front end sees pretty high pressure. It doesn't make as much difference as you would think between the front bumper and the undertray.
Old Jan 15, 2008 | 07:52 AM
fastkevin's Avatar
Not to steal his thunder (Im a DIY in may ways too ):
Hot Lap Kit (with various ways to install it):
https://www.evolutionm.net/forums/sh...d.php?t=277934
Like the idea, and especially the funnels, but I look at the front of the 9, and it's screaming for someone to design an integrated duct for the hose to mount to.I used to run dryer hose on my track car, and it worked, looked like crap, but it worked. The Evo's front facia looks like it'd be pretty easy to tap a duct into, and have it look like it belongs there. C'mon you engineer types
Old Jan 15, 2008 | 08:35 AM
dsycks's Avatar
I like the fact that it may route some the the air under the front lip upward which could make for a little lower pressure under the car and leave more air on the front lip for downforce.
If this was developed a little it may have multiple strong aspects!
Old Jan 18, 2008 | 05:36 PM
82NoMe's Avatar
Your idea looks great curious how you would measure flow. I went with a kit...
Old Jan 18, 2008 | 06:50 PM
sponge bob's Avatar
[QUOTE=82NoMe;5171014]....how you would measure flow. ...QUOTE]
I have no plans to measure air flow nor do I have any idea how this would be accomplished. My plan is to run alternating track secessions with the ducts connected then disconnected/blocked and measure rotor temps see how much lower I can get them. I’ll also closely watch pad wear so see if I can get more life from my pads. But until they scrape the ice of the roads around here this will have to wait until spring.
Old Oct 28, 2008 | 07:18 PM
AlwaysinBoost's Avatar
bumping this back up from the dead, I think its a good idea but I'm wondering how it worked out for the OP or if anyone else has tried something like it.
Old Oct 29, 2008 | 05:19 AM
apex electric's Avatar
WE need to do some comparison test using brake caliper temperature indicator strips.Check out HOERR Racing Products www.hrpworld.com Its a Porsche and GT racing product company. They state that caliper temperatures should not exceed 450 degrees.
Old Oct 29, 2008 | 08:50 AM
aka03's Avatar
not to bad
Old Feb 1, 2009 | 09:19 AM
mistersquishi's Avatar
I have had the idea to this for a long time. The question was, would it be enough airflow and how can I measure it? I have a way now! Get a cheap MAF from a junkyard. Hook it up to both methods, front bumper duct and this, NACA scoop on tray. The voltage measured will tell you flow.
Old Mar 11, 2009 | 09:46 AM
anthony_86gt's Avatar
Has this been tested? I'm looking for a ducting solution and i like the looks of this.
Old Mar 11, 2009 | 04:11 PM
18bora's Avatar
Shop vac attachments worked for me, but I plan on moving them further back when I lower the car.
To find out if they are working or not, you can use a temperature indicating sticker on the caliper to see if the temperature is changing.
http://www.mcmaster.com/ctlg/DisplCt...54027791282957
Old Mar 11, 2009 | 04:27 PM
Balrok's Avatar
Shop vac budget ducting FTW!! Hope you don't have a marbling track....or dead animals on the roads, or the random tree limb, or or or....
Old Mar 11, 2009 | 04:29 PM
eve-slow's Avatar
Love it! Great idea.
