My brake cooling solution idea
Old Jan 14, 2008 | 02:16 PM
sponge bob's Avatar
What do you think, its an idea I had for brake cooling duct system. I don’t want a big honken scoop on the front bumper or remove headlights or hang something under the front lip. A lot of people terminate a 2” flex hose right at or behind the bumper grill, to me you need something to direct air into the hose. I’m using naca ducts with 3” hose. So this is my idea. Untested of course as I just mocked it up.
Old Jan 14, 2008 | 03:13 PM
GTLocke13's Avatar
That should be a somewhat high pressure area, so you should get decent flow. Nice install.
Old Jan 14, 2008 | 03:50 PM
RallyDSM's Avatar
Veteran: Army
Great idea!
Why not duct from the front lower vents in the stock bumper cover?
RallyDSM
Old Jan 14, 2008 | 04:14 PM
Chabada15's Avatar
should work pretty good, 2 things 1, are you gunna put a small scoop at the beginning of the duct to direct even more air into the ducting? and where did you pick up those ducts
Old Jan 14, 2008 | 04:59 PM
inco9nito99's Avatar
Very clever, I like the idea a lot.
Old Jan 14, 2008 | 05:04 PM
RallyDSM's Avatar
Veteran: Army
I've use things like Shop Vac hose to corrugated irrigation pipe to vent brakes before... event hot tub tubing will work in a pinch.
Race Shops also have stuff just for this. All tied up pretty with bailing wire
RallyDSM
Old Jan 14, 2008 | 05:36 PM
rburris28's Avatar
Try looking up NACA ducts. They are the most efficient way to get air to move from an area of high to low pressure. Much better than scoops, and they are very low drag.
To the OP: Very cool idea, if the airflow over the undertray is laminar. Where'd you get the ducts?
Old Jan 14, 2008 | 06:23 PM
nothere's Avatar
I like the idea, but I don't think the pressure is anywhere near what it is on the face of the bumper.
Old Jan 14, 2008 | 06:27 PM
Smike's Avatar
Very nice!
Problem I found with the front areas (at least in ACD cars) is that the oil cooler is on the left and ACD pump on the right. So its hard to get a straight shot to the brakes.
How did you attach the hose to the brakes?
Old Jan 14, 2008 | 06:35 PM
fastkevin's Avatar
Yeah, I've always wanted to see a purpose made duct that blows air over a larger surface of the rotor. Getting air in is easy, getting sufficient air over the rotor surface has always been a problem for me.
Old Jan 14, 2008 | 06:50 PM
Smike's Avatar
Not to steal his thunder (Im a DIY in may ways too ):
(PS - there are SS lines there now)
Hot Lap Kit (with various ways to install it):
https://www.evolutionm.net/forums/sh...d.php?t=277934
Old Jan 14, 2008 | 07:09 PM
sponge bob's Avatar
Passenger side has an oil cooler scoop and I didn’t want my duct to share space with that. The driver side (the bigger issue) is filled with a bunch of ACD components and would need to be moved. It was easy to put this underneath, I hope it works
Old Jan 14, 2008 | 07:14 PM
sponge bob's Avatar
A scope in front of the NACA duct? I thought of that but as I said I don't want anything hanging down, now maybe adding something like a short air dam right behind the NACA, I will see how well this work first. NACA ducts can be found a race supply shops like Pegasus:
http://www.pegasusautoracing.com/keywordsearch.asp ,
I forgot where I got mine, been in the garage for a long time.
Bob
Old Jan 14, 2008 | 07:17 PM
sponge bob's Avatar
Agreed but I don’t like any of the other front mounted options, at least the ones I can imagine. When the EVO turns into a real race car then more options exist for me.
Old Jan 14, 2008 | 07:19 PM
tonelock's Avatar
looks great............
