AS gurus question about struts options...
Old Jul 4, 2008 | 10:08 AM
Andres06SE's Avatar
...for my IX SE. I just an alignment using Robispec specs, and A6's. Doing very well locally but I would like to go to Nationals this year and be more competitive, so would like to know my options, I cannot jump to STU this year..
Thanks
Andres
Old Jul 4, 2008 | 11:46 AM
Warrtalon's Avatar
There are no competitive AS Evos nationally, or at least I haven't seen or heard of any. Are you sure you want to do that?
Old Jul 4, 2008 | 11:55 AM
Andres06SE's Avatar
so STU would be the best option?
Old Jul 4, 2008 | 11:58 AM
Warrtalon's Avatar
We are at the top of the heap nationally in STU, so I would say yes.
Old Jul 11, 2008 | 12:54 PM
GTLocke13's Avatar
The Evo is too softly sprung and the shocks aren't right for autocross. You might be able to make a run at it with a set of these:
http://www.stranoparts.com/partdetai...D=0&ModelID=15
but (despite the $0 shown) they run somewhere around $3k. You may as well just go to STU at that point.
Old Jul 11, 2008 | 12:59 PM
Tarmacisback69's Avatar
awsome
Old Jul 11, 2008 | 02:01 PM
DaWorstPlaya's Avatar
https://www.evolutionm.net/forums/sh...ghlight=ohlins
You'll want the Ohlins fixed perch struts close to $1800 + in price. As others have mentioned, the EVO is going to have a tough time in A-Stock.
Old Jul 11, 2008 | 02:12 PM
Ookami's Avatar
Best chance to win in A Stock with an Evo at Nationals is to dress up in drag and run ASL, pray for rain or both!
Old Jul 11, 2008 | 06:17 PM
fastkevin's Avatar
IMO, a good suspension guy is worth as much if not more than a good set of CO's.
If you're gonna spend the money on 'em, you might as well spend the money getting them and your car optimized.
Old Jul 12, 2008 | 08:23 PM
ratt_finkel's Avatar
I'm curious why you guys think the Evo is no go for AS? The STi has proven extremly competitive. And I really doubt the Evo would be any worse. And honestly may be better! As for the original posters question. Get a set of DA konis inserts for the stock struts. 275 hoosiers, the lightest rims you can afford and a straight pipe after the cat....a nice free flowing filter might help too.
Or you can just let me drive it.
Old Jul 13, 2008 | 04:56 PM
conevadr's Avatar
For me it's the nut behind the wheel, but perhaps these pics from Toledo will help fill in the blanks...
http://philandjen.smugmug.com/galler...30907641_5LQcR
http://philandjen.smugmug.com/galler...30933127_KCGgZ
http://philandjen.smugmug.com/galler...30930559_iCHHK
http://philandjen.smugmug.com/galler...30944742_nGcMR
I've got DA's (currently rear only - front blown), an upgraded bar, Hankooks, plus K&N filter and no muffler.
Generally the problem is that the stock EVO (8/9) has more body roll than an overweight belly dancer. It's not that the inside rear is always off the ground, it's that it takes too long for the body to transition back and forth. The bar and shocks help, but it just isn't enough. I'm currently running without my front underlip spoiler, as both ends are worn down from dragging on the ground.
With the larger motor and shorter gearing, the STI has a bit more grunt, especially off the line and in tight corners. The EVO 5500 rpm launch limiter, clutch restrictor pill, and hi boost/low compression motor makes the EVO tricky to launch consistently (for me). At Toledo on the sticky concrete, I couldn't keep the tires spinning and was turning 60' times that were 3-5 tenths behind the STIs.
Also, the STI torque shift to the rear helps it rotate coming out of corners.
Finally, the EVO needs an alignment that isn't exactly street friendly to help it manage sweepers.
The EVO is a ton of fun to drive - I enjoy mine every day of the year in all conditions including winter TSD rallys, but IMHO it can't hang with the STI's or the other newer big guns in AS (except maybe in the rain).
George M
Old Jul 13, 2008 | 05:22 PM
Warrtalon's Avatar
FYI, the stock stationary limiter is 5000rpm.
Old Jul 14, 2008 | 01:21 PM
GTWORX.com's Avatar
The Ohlins are well under 2k from us.
Other options that i know of are revalved Bilsteins or custom JRZ ($texas).
As others have said, STU is more EVO "friendly."
- Andrew
Old Jul 17, 2008 | 02:50 PM
I think conevadr hit the nail on the head. The EVO 8/9 is just too softly sprung to keep up with the amount of grip. The EVO X on the other hand is very interesting. It doesn't seem to have as much body roll as the older models and I haven't seen it lift the inside rear wheel on our local events.
Old Jul 17, 2008 | 03:08 PM
goofygrin's Avatar
That's me 1st time out with the X.
LOTS of body roll on the beastie. And it's heavier than the 8/9 too which isn't going to help anything in AS.
Illest35RIX
For Sale - Cars For Sale
18
Sep 2, 2014 01:15 PM
Andres Mesta
Jan 6, 2014 07:59 PM
Andres Mesta
Jan 3, 2014 11:23 AM
Andres Mesta
Dec 22, 2013 08:08 AM
Andres Mesta
Sep 26, 2013 10:29 AM
