Best Rim for A Stock
Ok, I read the whole A Stock sticky. This is my conclusion if you want to run 275 kumho 710's. You need 33 offset in front and 38 offset(stock) in rear. It seems like the lightest rim that satisfy this criteria is getting a set of stock BBS with 38 offset at 17.8 lbs each. Then purchasing 5mm H&R Trak Spacers for the front. Am I correct? I really like the Enkei RPF-1, but offset is 35
Volk makes the CE28N in a 33 offset. I ran this wheel when I was in A Stock. I ran 245s in the rear and 275s up front. I don't know if the 275s with the 33 offset would rub in the rear though. The 33 offset with 275s in the front rubbed on the inner plastic fender liner a little, but it's really no big deal.
The wheel barely weighs 16lbs.
For that matter, I have a set of Advan's that have a +35mm offset as well. Once again, just searched and found 'em. I only searched these two manufacturers, there's probably more.
Edit: I take that back. I also found 5zigen in the correct offset. They're also light and inexpensive, with a good reputation of holding up on the track.
Sorry - my bad... my spacers aren't H&R, they are 1/8th inch (3mm not 5mm using stock lugs). I don't remember where I got them, but they look like these
http://www.sfxperformance.com/parts/GORSP601S.htm
George M
George M
George M
FL_SilverEvo8
Oct 4, 2013 10:25 PM
awdboosted
Jul 3, 2009 01:18 PM
Chamama
Jul 29, 2005 06:58 AM
