Kill switch install
Old Dec 23, 2008 | 12:17 AM
Balrok's Avatar
Kill switch install
So, googled around a lot and found various articles on installs for kit cars and spec miata's on ways to install a kill switch with the alt. protection. Per the NASA rules we need one, so I got the one from Pegasus racing, which looks like the standard 6 pole with the big red key. I know a lot of you guys have done this already, especially the big time shop cars and the rally guys, can any of you provide steps and/or pictures on the best way to go about it? From the electrical/wiring point of view. Thanks.
Old Dec 23, 2008 | 05:25 AM
Bimmubishi's Avatar
Here is a commonly used PDF from Longacre.
http://www.longacreracing.com/instru...ext/4578PI.pdf
Old Dec 23, 2008 | 08:54 AM
Balrok's Avatar
Conflicts with what i've read on the 6 post ones like the one I have. Need Evo specific as I don't have a wiring diagram to identify which one's witch...yes I can trace the cables but again...which one's what
Old Dec 26, 2008 | 06:18 AM
Bimmubishi's Avatar
I can try to help you on this post if you have any specific questions.
Old Dec 27, 2008 | 08:25 AM
Balrok's Avatar
Thanks bro, specifically speaking I need to know what needs to be done with a 6 post switch on a lancer evolution....the 4 post one posted earlier has different circuits so it's different but the concept is the same. What I've gotten so far is:
1. Run the positive cable from the batt through the big posts on the switch to the bus (rockford fosgate bus with everything in it from batt relocation)
2. On terminals 3 and 4 - Somehow rig up the supplied 3ohm 11 watt resistor and some kind of alternator ground protection thing that I don't fully understand yet but the bigger question is how would you go from an 8ish gauge cable, and connect the resistor which is pencil thin, then to a big ground cable again.
3. Wires from Ign switch and Ign coil...which i dunno which ones those are, to terminal 5 and 6. So you find the end of each wire and run those "through" the switch that way it separates the switch from the coil....but would that even shut off the car if the cars already running?
Old Dec 30, 2008 | 06:57 PM
Bimmubishi's Avatar
Balrok, I think I found a good 6 post diagram. PM me your email and I'll send it to you.
Sorry about the delay. Work has been busy lately.
Alex
Old Dec 30, 2008 | 10:41 PM
currahee474's Avatar
Alex
Could I get one of those as well?
currahee474@gmail.com
Thanks in advance!
FCR0423
Evo X How Tos / Installations
Sep 16, 2016 11:41 PM
shane_evo7
Aug 12, 2016 02:16 PM
wingless
May 2, 2011 04:32 PM
evolutionpower
Apr 7, 2008 05:31 AM
chrismnj
Sep 14, 2007 01:19 PM
