Wicked Awesome Splitter Action
Old Mar 9, 2009, 03:09 PM
  #46
EVOlutionary's Avatar
Originally Posted by chu
I think the end pillars are extended too far from the body line. I'm guessing you had the idea to make them sit flush with the canards above? I would bring them in more cloder to the APR lip. I will try to find an article from RACER magazine that discussed this, and send to you.
I tend to agree. I would like to know what the intended effect of this part is on a flat splitter element? I know the end plate is functional on the Voltex splitters because the Voltex unit has approx. a 12* AOA in that area. The end plate forces air to flow over the wing rather than sliding off the end of it . . .
Thoughts?
EVOlutionary
Old Mar 9, 2009, 03:24 PM
  #47
chu
chu's Avatar
I found the article I mentioned several posts ago. It's in the September 2008 issue of Racecar Engineering under the Aerobytes column, written by aerodynamics consultant Simon McBeath. I will scan the article and post it up tomorrow.
Old Mar 9, 2009, 08:52 PM
  #48
jid2's Avatar
The splitter acts as surface area for downward force resultant from the high pressure area at the front of the car. The end plates should help maintain the high pressure at the absolute edges of the splitter. ( I made that up).
I made them that wide because my tires hang out in that area with the race wheels on. I'm going to add some air-dams on the leading edge of the wheel wells to cover the tires up and I think that will come pretty close to the endplates.
Old Mar 9, 2009, 09:26 PM
  #49
Originally Posted by jid2
Added endplates.
Can you share why you chose to have the slot in the end plate? It looks a lot like the recent Voltex units. . .
Old Mar 9, 2009, 09:44 PM
  #50
Pirana's Avatar
hey how much for the diapers ^ I just ****ted my pants, hehehe
Old Mar 9, 2009, 09:51 PM
  #51
jid2's Avatar
Good engineers copy smart people. F1 cars use the same sharp edges to create vortices.
Old Mar 9, 2009, 11:36 PM
  #52
RaNGVR-4's Avatar
I'm going to add some air-dams on the leading edge of the wheel wells ...
Good man, you know what youre doing
I assume something like this:
To help evacuate the wheel wells and such?
Old Mar 25, 2009, 09:15 PM
  #53
CroatianKid's Avatar
watch top gear more than
Old Mar 25, 2009, 09:20 PM
  #54
NativeSS's Avatar
damn, ur doin it up and not for much money. u should start selling this shyte... make some bucks back.
Old Feb 26, 2010, 11:22 AM
  #55
MitsoKid's Avatar
wow this was probably the most informative thread I have come across in a long time. Lots o good pics and links. Deserves a bump!
Old May 8, 2012, 08:43 PM
  #56
boomn29's Avatar
So I've been screwing with aero parts on and off for the past year, slowly adding and improving things. I got an APR splitter last year and only had time to mount it in the stock, lame APR fashion - to the bumper. The angle of attack was +4 degrees and it really didn't stick out that far. Here's a picture of what it looked like when I first mounted it with my original air dam.
Hanging from 4 cables, and 5 bolts to the chassis. It's setup to adjust between -2 degrees and zero. A change in spacer blocks can make it go from -4 to -2 degrees as well. But that gets it pretty low at the tip. I'm going to start at the -2 to zero range.
Jid2, are those connection points in the middle the same location as the stock bumper screw holes? Any other closeups?
Old May 9, 2012, 06:01 AM
  #57
EVOizmm's Avatar
Thought I'd post up my splitter build. Did my first event last weekend and it seemed to work pretty good.
http://blog.365racing.net/2012/04/02...plitter-part2/
Old May 9, 2012, 08:18 AM
  #58
jid2's Avatar
I think I just eyeballed them in a place that looked about right. It's not super critical, I see guys running 10 billion supports and I don't think it's needed unless the splitter material itself cannot support any real loads. 4 points should be enough.
Old May 9, 2012, 08:27 AM
  #59
ratt_finkel's Avatar
Is that Josh's old car?
Old May 9, 2012, 11:01 AM
  #60
EVOizmm's Avatar
^ Yes it is,
Quick Reply: Wicked Awesome Splitter Action
