2009 Racing ToDo List
As racing season fast approaches (and for those in warmer climates, possibly has begun), what do you have left on your ToDo list to get ready? Mine seems WAY too big to get done till summer... but I knew 2009 was going to be a prep-season for me.
You can find my most updated version of this list, including what is already done, here:
http://blog.the-shadows.net/?page_id=117
Code:
Installation Required: Install Nisei Battery Tray Install AMS brake cooling kit Flush brake fluid. Flush coolant. Change oil to Amsoil Race Oil & send old oil in for analysis Change transmission fluid (after cooler) Change transfer case fluid with Amsoil Severe Gear Change rear differential fluid with Amsoil Severe Gear Install AMS Moustashe Bar Eliminator Replace wheel studs ARP->Stock and Spacer Studs->ARP Install TRE prepped 6spd & Exedy Clutch/Flywheel Rexspeed rear bumper extensions Rexspeed side skirt extensions Heat wrap & Install new downpipe Truck helper spring install Cut rear brakes Trailer underside rust coating Inspect drivers side headlight & repair Fabrication Required: Trailer Ramps Tow Hooks (front & rear) Voltex Brake Ducting Mounting Plate for Winch Trailer Wiring Harness Widen Front Fenders Rework Oil Catch Can & create mounting bracket Transmission Cooler setup Oil Cooler setup Re-clearance APR rear diffuser to exhaust Better Camera mounting system Canopy System for Trailer Optional Installation: Interior Weight Reduction Passenger side airbag removal (means dash removal) Optional Fabrication: Custom Seat Mounting Temperature Pump Controller Touchscreen Datalogger (EvoScan) Would be nice: Trailer TireRack Trailer Toolbox Mounting System Custom Carbon Fiber Front Splitter Touchscreen Datalogger
I'm actually de-modding some to slide down to a lower class in NASA. Here's my list:
Remove coilovers - install new Muellerized JIC Suspension
Remove Hotchkis RSB - install stock swaybar
Remove HKS Air filter setup - install stock airbox
Remove UICP & LICP - install stock piping
Remove mini-radiator - install upgraded radiator
Replace Mini Battery
Install new brake cooling kit
Flush brake fluid.
Flush coolant.
Change oil
Change Head Gasket
Install ARP Head Studs
Install Timing Belt & Belt Tensioner
Install Spark Plugs
Install Oil Temp, Oil Pressure, Boost guages
Install new gauge panel
Install Energy Rear Trailing Arm Bushings
Install AMS 5 speed shifter bushings
Get car aligned
Fabricate passenger airbag cover
Fabricate/buy front under panel
Tow Hooks - Redo front; install rear
& rear)
Optional Installation/Fabrication:
More Interior Weight Reduction
More Exterior Weight Reduction
Fix exhaust rubbing issue
Would be nice:
Tow Truck
Tow Trailer
Trailer TireRack
My first track day was last weekend, so I've been busy for the past few months getting ready, OK, it's been 9 months. I had to finish break-in and tune the motor, as well as fabricating a bunch of stuff like new brake ducts and aero additions. Barely finished. You can check my build thread for all the gory details and pics.
Now that I've done a shakedown I've got this list to address before the next track day. I was going to do one in April, but have decided to pass on that and not go again until May. I hate the stress of always needing to work on the car. I need a break. So here's what's next.
Before next track day
- Finish Accusump install
- Build new high flow catch can and breather system
- Build a double pumper fuel system
- Tune on E85
- Buy some 2 piece rotors and install.
Mid-Summer
- Build a rear diffuser
- Build a GT wing
Here are some pics form last weekend in the rain
Video
http://www.vimeo.com/3672244
Don't need you guys today...
Need to fix this action.
Need to finish this.
- Tune on E85
Mid-Summer
- Build a GT wing
Video
Speaking of race gas, have the prices lowered? Last summer I payed $8.75 a gallon for Sunoco 100 unleaded. I have not called New England Race Fuels this year. I noticed the same Sunoco 100 was cheaper in the new pump at Pocono International Raceway last summer. Watkins Glen has Sunoco pumps, but I did not check the price last fall.
My NASA Super Touring 2003 Evolution list this phase. Remove stock doors and install gutted carbon/fiberglass set. Rebuild/modify gearbox, rebuild motor, install RS front limited slip, modify rear limited slip, re mount driver seat, install Accusump, install on board fire extinguisher, install cool shirt cooler and drink bottle, Motorola radios. NEED SPONSOR to repaint car in company color and logo's....
Progress update!
DONE:
Remove UICP - install stock piping
Flush brake fluid.
Flush coolant.
Change Head Gasket
Install Spark Plugs
Get car aligned
Still to go:
& rear)
Remove LICP - install stock piping
Change oil again
Get car re-aligned
Had my first shake-down trip to the track last night. Just an afternoon instructing for the SCCA. Car felt solid; no issues besides some hot brakes (need to flush fluid) and some bad tire pressures.
Running my new gauges for the first time; what are other people seeing in terms of Oil Temp? I was seeing around 215 during my hot laps. Any feedback?
DONE:
Flush brake fluid.
Flush coolant.
Change Head Gasket
Install Spark Plugs
Get car aligned
Still to go:
& rear)
Change oil again
Get car re-aligned
- Install/fab front undertray
- Once undertray in place, redo NACA's for brake ducting
- Install rear tow point
- Scrub in 285/30's and determine rubbing points
- Get new fuel system and tune for E85
- Upgrade Ecu/Engine/Drivetrain/Tranny/Diff's/Turbo Kit/Brakes
- Finetune brake pedal spacers for comfortable heal/toe final position.
- Get Aero....lots of it.
- Somehow pay off debts/bills and have 1500 leftover each month for track days.
FS[Northeast]: 2006 Fully Built Rally Red Evo IX RS 38k miles
Kraise
For Sale - Cars For Sale
19
Nov 14, 2015 04:08 AM
Jhurley_EvoVIII
Sep 28, 2015 04:58 AM
APM Racing
Midwest Region
Mar 18, 2014 07:58 AM
APM Racing
Midwest Region
13
Jul 1, 2011 01:55 PM
