wow... 09 Ralliart isn't legal in STX like the WRX
The 09 Ralliart Ralliart weighs about 3500lbs vs the 02-04 WRX weighs about 3000lbs. Thats a 400-500lb difference!
Both cars have Macphereson struts in the front.
The Ralliart has mulitlink rear and the WRX has macphereson struts in the rear.
Ralliart has helical front diff vs WRX has open front diff.
Ralliart has ACD vs WRX has viscous center diff.
Ralliart has rear mechanical clutch diff vs WRX has viscous rear diff.
Ralliart has 237HP vs WRX has 225HP. Boost modification isn't allowed so power gains aren't as significant.
And the WRX has a better weight distribution (closer to 50/50).
IMHO, given all these suspension and drivetrain differences does not make up for the 400-500lb difference, especially on an auto-x course. But stranger things have happened ...
Talk to Fair about how the X MR transmission has helped them.
I've seen it from the outside, the car shifting to 3 and back to 1 where you'd NEVER do it if you were rowing your own gears.
On tight technical courses, I think the dual clutch is definitely an advantage.
Plus LFB is easier and you don't ever have to take your hands off the wheel!
I agree the 2.5L WRX's shouldn't be allowed in STX but ...
02-04 WRX's are 3100+, MAYBE 3100 even in STX trim with light seats. Ralliarts are 3400 lbs. Everything else you listed is in the Ralliarts favor, and subarus Don't have better weight distribution, the engine hangs two feet over the front tires. Seeing in person how crazy the SST is on a course, the Ralliart has an advantage. We may only shift once or twice, but the SST shifts allot, keeping the car in a good powerband.
http://en.wikipedia.org/wiki/Subaru_...C_.282002.29_2
(I know its Wiki but I remember these numbers being correct because I used to own one)
The exact curb weight of the 2009 Ralliart is 3,462lbs.
http://www.mitsucars.com/MMNA/jsp/la...s.do?loc=en-us
That's a 377lb difference!
The weight distribution on the 09 Lancer Ralliart is 60/40. The weight distribution on the 02-05 WRXs are 56/44. I don't know but this seems like a pretty large difference to me. Not to mention since its a boxer engine, the engine sits lower than the I4 on the Ralliart, effectively lowering the cg.
No doubt the TC-SST is an advantage for the Ralliart but most auto-x courses are 2nd gear courses anyways. If anything the TC-SST should be considered as a small tool that equalizes the advantages the WRX has over the Ralliart.
IMO of course, nothing official, blah, blah...
Daworst, Weight is not everything anymore. Its just not. And thats coming from me; I am a huge proponent of lightweight cars, trust me. BUT, ~300 lbs (my brothers old WRX was 3180 on the scales, it was an 03) is not enough to trump a bit more power, along with all its other advantages. Prepped correctly, the ralliart would pwn up in STX. Look at how well fairly un-prepped STU evo X's are doing locally so far this year...
d
EDIT: My under-prepped car (stock seats, stock battery, added radio, heavy wheels, etc.) weighs 3199 WITH ME IN IT.
Hmmm...almost everything you listed favors the Ralliart. I would also challenge the weight difference. Keep in mind, cars are evaluated in full 100 precent STX trim, so saying the stock tires suck, or it only has 237 hp doesn't mean much. The MIVAC motor responds *very* well to tuning, and the active center diff add up to a potential class killer. Note also that STX should see lots of diversity with the RX8 and the Colbalt coming in. The fact that the WRX is in the same boat (although due to displacement), and that initial classing is usually done on the slightly conservative side, makes this an easier choice and one that was pretty well supported.
During Nats 08 the fastest EVO was an 03/04 EVO with an open front diff, viscous center diff and sans MIVEC. These are all quantifiable results.
My point being, I believe that everyone @ the SCCA BOG (STAC, whatever) is putting too much weight on the benefits of these minor incremental upgrades. Weight is the bigger player in the overall picture (I'm with donour on this)... I rest my case.
