View Poll Results: TT/TA tire options for wet tracks?
Street tires
42.86%
Hoosier Rains
21.43%
Full tread r-comps
35.71%
Other (post up)
0%
Voters: 14. You may not vote on this poll
Rain tire options for the track?
Old Jun 20, 2009 | 10:24 PM
Balrok's Avatar
Also remember if your in a multi-lap session (I.E. an ST race or regular session etc) that you'll want to hit the puddles every now and then to help "cool" the street tires as they aren't really designed for the abuse like using r-compounds. The same applies to rain slicks, but in their case you'll actually blister the tire if they overheat. So use your best judgment with your weather patterns. If the track dries out quickly, I'd still say a full tread r-compound is the way to go if you don't have a crew to swap tires, and your going for TT/TA times.
Old Jun 21, 2009 | 12:24 AM
RaNGVR-4's Avatar
NT-01's are terrifying in the rain, even at full tread depth. The Z1'a are great for a street tire, as are the R1R's. the new Hankook RS3 might be decent in the rain. You cant beat a hoosier wet or possibly the new kumho wet though.
Old Jun 21, 2009 | 02:33 AM
meanmud's Avatar
Old Jun 21, 2009 | 05:02 AM
Robevo RS's Avatar
Originally Posted by WAM
If you're considering a street tire for dual duty, check out the Tire Rack test results for the Goodyear Eagle F1 Assymetric.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=101
It wet-lapped their test course a second faster than the Dunlop Z1. Doesn't look near as sexy, but when you compare actual performance results...looks a lot better.
I have the Eagle F1 for DD. Not even close in rain never mind dry, to the Toyo R1R.
I never used the Dunlop Z1, so i have no comparision to that.
Old Jun 21, 2009 | 07:08 AM
Toxin's Avatar
Michelin PS2 rock in the rain.
But you didn't define what your main issue was - if it's just a wet track without puddles, then r-comps will still stick (chop em up a bit so they warm up faster, just thin slight lines between the treads)
My pirelli group N rally tires, semi used up already, I just used em to burn em up on a track day, but they stick in the rain once you heat them up... I'd say they can compare to an average/good street tire in the dry, once they heat up in the wet.
If you have puddles on the track though, aqua planning and the tires on the picture share the same name, you can be sure of that
Johnr352
For Sale - Wheels / Tires
May 10, 2012 03:09 PM
EVOlutionary
Aug 26, 2011 02:50 PM
racer145
Apr 23, 2011 06:30 AM
boomn29
Sep 13, 2010 05:36 PM
racer145
Aug 31, 2010 11:58 AM
