rollcage/strucure ?
is this something I should consider on the CT9A chassis? Right now our plan is to box the rear strut tower mounts and weld to those. Where you have your cage mounted is where I currently have 3 plates (2 on both sides of the frame and 1 on top) that hold my harnesses in securely. Maybe I should re-design this?
Robi
[QUOTE=KevinD;8014714]robis cage is a minimalist cage, meeting the NASA TT rules and essentially not much more.
if you read the rules you'll see all the bars he has are called out specifically. the cage i'm building in my car is nearly identical to robis as well, but only because i'm also doing a cage that meets the rules and only 2 tubes extra. also i'm not doing the X bars on the passenger side, i'm doing the nascar bars because i have a passenger seat. you will want to cut the rear seat back "V" section out in order to have the proper roll hoop supports to the rear strut towers, but even that can be done without cutting it out completely.
[QUOTE]
this cage meets NASA and SCCA W2W specs and NASA TT and Redline TA rules. Just the "minimums" but imo that is what rules are for what you cant see in the picts are the 24" of welds directly between the roll cage and the factory chassis without the need for a bunch of gussets because we fit the cage so tight to the structure.
Robi
[QUOTE]
Robi
well according to the nasa rule book you cant use gussets because tech has to visually inspect all welds 360 degrees around the tube.
We've got it all figured out now, we are just trimming the "V" section to accomodate the roll bars and gutting the doors. I got a strut tower bar for the rear so no tube goes their and we are doing nascar style on both doors.
It works out rather well, and keeps cost down so the shop can afford other stuff to do, like rewire all of the electrical, make tow hooks, fiberglass ect ect..
For rally cars, NASA rally rules follow the FIA rules, so I guarantee that gussets are required on new builds.
FWIW, there are at least two types of gussets you can incorporate, plate & "taco." A plate gusset doesn't block the view of a tube getting welded all the way around, but a 'taco' gusset would make it impossible to inspect.
Dave
crf inc.
Jun 16, 2015 10:49 AM
Joe@robispec
Evo 'For Sale' Suspension / Brakes / Handling
50
Oct 10, 2009 08:18 PM
