Additional Bolt-in Roll Bar support/backing plates
Old Feb 13, 2011 | 11:15 AM
delongedoug's Avatar
How comfortable are you guys with welding the thin floor pan? I see welding on the door frame since that's stronger. I think that might be the only welding doable with these.
Old Feb 13, 2011 | 12:49 PM
Robevo RS's Avatar
Originally Posted by KevinD
putting plates on the outside of the car only helps if your cage is getting pulled (potentially from landing on the side, or a side impact). on a upsidedown crash like that mustang, backing plates wont do anything, and then your relying on the strength of the actual skin of the floor pan. exactly like xtnct said. but if your at all serious about your safety the base plates should be welded in. bolt in cages are not meant for serious motorsports.
There is a section in the FIA - WRC rule book how and which type of bolt in cages you can run. With a detailed connections and other pictures. Aviabale on they website in the safety rule section.
Old Feb 13, 2011 | 12:52 PM
Robevo RS's Avatar
I think that picture a proof of the wrong or badly installed cage. We don't even know which one. Just the proof the rollcage is not invincable if it is wrongly installed or a bad design.
Rob
Old Feb 13, 2011 | 01:18 PM
xtnct's Avatar
Originally Posted by Robevo RS
hm... my Cusco made 8 point/ i forgot the name a way they call it/ FIA proved and certifyed racing bolt in cage plates, by the instructions we had to put the plates outside of the body... Actually they wont even fit and sit inside well in the car.
Yes, my bar came with plates for the outside as well. The inside of the bar has a plate welded on as well, But these are more like 3x2 or 3x4. The plates talked about in this thread go above and beyond the plates that come with the bars in order to spread out the load even further and reduce chances of a punch through.
But again, this is only a band-aid solution and it has its limitations. Best way to do this is to weld in some proper mounting supports if possible.
Actually all this is known. You just have to search for it. I recall reading threads about this incident where all this was discussed but gave up as the threads were getting too long and cluttered by "keyboard racers".
Old Feb 13, 2011 | 01:51 PM
Robevo RS's Avatar
Oh, so you actually add on one extra pates between the original ones
Now make sense for me my cage came a equally big enough base plate to welded on the bottom of the cage /inside/
Old Feb 13, 2011 | 01:58 PM
xtnct's Avatar
Oh, so you actually add on one extra pates between the original ones Now make sense for me
Exactly!
Old Feb 13, 2011 | 03:39 PM
Robevo RS's Avatar
Oh, so you actually add on one extra pates between the original onues
Old Mar 29, 2011 | 07:34 AM
Plates are installed. The 1/4" steel is pretty darn heavy duty and with the tight Autopower roofline fitment, the headliner had to come out to accomodate the additional 1/4" of height to the unit. Not an issue for me, but if you want to keep your interior, maybe get 1/8" plates. Hope this thread's useful for others in the future.
Old Mar 29, 2011 | 10:31 AM
Vehicle336's Avatar
This thread is great, in for bookmarking and subscribed. I shall be doing the same thing sometime this summer.
Old Mar 30, 2011 | 11:43 AM
honda-guy's Avatar
Well, since I take my bar out in the winters (so I can carry my kids in the back), it was easy for me to measure the plates.
Thickness: 3/16"
Angle: 40* (Plate 1) and 43* (Plate 2)
Angled part height: 1.25" (Plate 1) and 1.5" (Plate 2)
Plate unbent (flat): 6"x8"
Reason for the discrepancy between plates is that a vice and a big hammer was used to bend them as opposed to a proper bender. I recall the 40* is a hair too little, so I'd go with something in the 41/42* range if you can actually measure the angle.
if you want to make a drive to Carlisle, i have welder buddy that can weld those plates in for you for a decent price. you'll just have to scrape off those sound insulation stuff off first
Old Apr 3, 2011 | 11:55 AM
Old Apr 18, 2013 | 01:46 PM
killerpenguin21's Avatar
Originally Posted by delongedoug
Anyways, I gave him the specs from xtnct above (thank you again! ) and drew up a rough template in Paint.
Here's the finished product:
So there you have it. All the blueprints to get these made yourself. I'll be doing the install next weekend.
any chance you could have a set made up these days? having trouble finding a shop to do it.
Old Apr 28, 2013 | 05:43 PM
EvilTechnology's Avatar
I'd like some too.
Old Apr 17, 2014 | 11:18 AM
dave_evolvix's Avatar
Bumping up from the dead. Can these plates be purchased? Anyone have photos of these welded in place?
Old Mar 16, 2015 | 04:44 PM
mkcolgan's Avatar
Re bump from the dead, Also in to purchase these plates.
Mike
