Advice on track time
Yes you should if you're changing your fronts - keep them identical. Last thing you want to be concerned about is unbalanced braking on your first day. Just make sure you're confident and comfortable with the car "before" you go to the track, so that you can enjoy the first day and learn rather than be worried about something not holding up or breaking.
Better brakes never hurts, But the drivers comfort level with the feel of the car, is paramount to your first venture on track. Listen to your instructor !! And try not to be to nervous about driving "on track" it is MUCH safer than any street. You will have a great time for sure, then you will be hooked like the rest of us. Pete
yes it will definitely be worth it. for me a driver mod is the best and most useful mod you could do. plus you will need to get as much lesson and seat time as possible. just like what spdracerut said fresh fuilds is very important. most of all the brakes. if you can, bleed your brakes for day 1 & 2.
A driving school will ALWAYS be the best mod. Most gear heads cars have been modified way past their ability. At a recent school I ran one of my female associates in he bone stock Colbolt ran rings round a guy in his very modified 450bhp STi
EVOTELL
SCCA Instructor
^^I would get a set of Hawk HP+ (or Ferrodo 2500s) for every corner and take them with you to the track. Check your current pads every other session to make sure that you have material left, swap them if you need to. You can run the HP+ on the street as well.
Have a great time!!
Have a great time!!
I dont think you need to go out and buy new pads for your first event. run what you have on the car, as long as there is more the 50% material left, and you'll be fine. I would be more worried about flushing the brake fluid. you will probably boil the fluid before you cook the pads on your first time out. Castrol LMA is a good fluid if you don't want to drop the coin for Motul. Also flush the clutch while you're at it.
you have lots of good advice in this thread, if you follow it you're going to have a great time!
Have a great time!!
Have a great time!!
The more experience that you get hot lapping, the further you will push the brakes to their limit, so eventually the 2500s will not be up to the task. But for now, use the 2500s, then have a spare set to use as your street pads when you have progressed enough to require track pads. If you start tracking your car on a regular basis, a spare set of brake pads is a requirement everytime you go out.
EriCs,
If you want to beef your brakes up a bit, you may want to try the new CL RC5+ compound. I think they would be perfect for your needs. They are completely streetable (low dust, low noise), but have great bite from cold to hot. They have been torture-tested on the track by a number of users, and have held up quite well. You can see some reviews here: http://www.essexparts.com/brake-pads...s/cl-customers
You won't be pushing them nearly as hard as most of these guys, and I think they would be just about ideal for your situation. I believe they are the best street/track pad available on the market today for the Evo. They will certainly provide far superior performance and much longer wear vs. Hawk HP+, with less dust and noise. I wouldn't be at all surprised if a set of RC5+ lasted you the rest of the year for daily driving and the occasional monthly track event, autoX, etc.
Front Evo IX= http://www.essexparts.com/shop/brake...e-pads-65.html
Rear Evo IX= http://www.essexparts.com/shop/brake...e-pads-59.html
AP Racing fluid is extremely popular in professional motorsports, and they have a wide range of options to fit many budgets:http://www.essexparts.com/shop/brake-fluid.html
For your application, AP Racing Super 600 would probably be ideal.
If you want to spend less, AP DOT5.1 will still be much better than what you have in the car now.
When you get to the event...check your ego at the door and just have some fun out there!
just lowing your boost probably isn't a good idea, it can move you into load cells that you were'nt necessarily tuned for. Its much better to just spike your tank with 5 gallons of 100 oct
I'll be heading up Friday so I'll probably drop the car and trailer off Friday night and then go hit the hotel. I'm bringing the wife and my twin 2 year olds.
(If anyone has any hints on NJMP as to where to paddock, etc. please let me know)
Haven't figured out if I am going to attend at the end of may or beginning of June? I think BMW association has an event June 7-8. Its only around 360 or so for 2 days. Its not definate but the sooner the better!
I will have to talk to my tuner and see if its a bad idea. Running at full boost is too much as I am at 400whp on stock Turbo right now. I will maybe have him give me a second map.
