Changing tires at the track, impact wrenches etc
There's the guys that come to the track and setup shop. Very very helpful.
But $140 to mount 4 255/35-18's adds up. Figure 4 sets a year of those, and at least 2 sets of others and your around $750 in labor pretty quick. I'd also like the ability to flip some tires inside/out personally.
Yep, $140 for 35 series 18's including tire disposal. I think it's less if you order through them, but I fortunately win most of mine through Hoosier contingencies or purchase from TireRack. There's some places around my house that I've had mixed luck with and some I don't trust (not with custom 3-piece rims!). Cost is still $100-$120 alltogether.
+1 on the Snap On CT6850. It is perfect for lug nuts. It can break free lugs torque'd to 100lb/ft and if you don't wail on it, it will torque to around 80lb/ft so you do the final tq with a tq wrench.
These are relatively prevalent, used, on ebay.
Battery can be rebuilt for ~$50.
I always use anti-seize due to the fact that I swap wheels at least 10 times a month. When I wasn't using it, I snapped wheel studs due to the stress of lugnuts being taken off/torqued all the time. One of our experienced (note: 2009 DSP national champ) autocrossers suggested that I clean the studs periodically and apply anti-seize. I combated the overtorquing issue by lessening the torque that I apply to the lugnuts.
Now add in the cost of taking 3 sets of track rims and tires thats just for myself and having the ability to flip flop tires if they get bad shoulder wear , the ability to run used tires that you pick up from places plus the 100s of friends tire that have been changed in the past year ask for a donation for upkeep on the machinery and it has paid for itself already .
Back on the original topic best cordless impact on the market when i bought it last year.
http://www.milwaukeetool.com/Product...a+V28%e2%84%a2
Overkill yes ,,, has it ever failed to remove anything on my car , no.
The nice thing about these li-ion batteries is they provide nearly full power almost until fully drained , and still work decent in the cold not to mention the ultra quick charge time of around 30 min.
When i change on the track i use a breaker bar to loosen , (the gun will do it but you risk wearing out lug nuts and studs with changing often)
And to tighten as mentioned by others just seat the rim with a quick blip use the torque wrench and ALWAYS RECHECK after a run or two .(you already knew this).
undercoverpope
20
Jul 20, 2011 10:54 AM
