2.0L for road racing???
Old Nov 3, 2010 | 11:46 AM
Boosted Tuning's Avatar
Originally Posted by SoCal Rally
If you're talking about real road racing, as opposed to just doing HPDEs for fun, the first thing you need to do is get ahold of the relevant series' rulebook, and figure out what is allowed ... and either way, I'd focus on suspension and brake mods first, if allowed, before looking at power.
I agree with this, problem is I already have power (FP BLACK), and need a built motor so I can have peace of mind while on the road course, because my current motor has 122K miles on it.
My car already has Wilwood BIG brake kits, front and back, WORKS springs, RRE rear sway and I will be getting some good CO and other suspension mods soon.
Thanks for everyone's input.
Old Nov 3, 2010 | 04:41 PM
AlwaysinBoost's Avatar
^ that is my question... If you're doing HPDE's, TT's and even W2W racing, what kind of BUILT motor did or would you go with and why?
Old Nov 3, 2010 | 05:11 PM
It will be a BR stg 3 block and stg 3 head. I was gonna do 2.3L, but I have now decided to do a 2.0L. I was gonna go with the 2.3L because of the low end it has, but have now decided I would rather have something more reliable and balanced, which can rev higher, so Im going with the 2.0L. And like I said, I do a fair amount of drag racing, where the 2.0 shines.
At first, Ill be doing alot of HPDE's and then moving up to doing TT and may also find a class I like in SCCA or NASA and run in it. I understand whatever TT event or SCCA/NASA class Ill be running in will have rules I have to follow.
I guess, what I meant by my question in the OP, is "are there 2.0L track EVOs that set lap records, win time attack and win championships?"
I guess my reasoning for the questions is that if the 2.3L has more low end and is supposed to be better for road racing, do 2.3L set all the records and win all the event, or are 2.0L still competitive? (The exception of course, is the classes/events where you cant run a 2.3L per the rules.)
Old Nov 3, 2010 | 07:37 PM
Robevo RS's Avatar
i cant think any other race where you really need that low end unless its autoX or Rally, where the 2.2 and above, will give you any advantige over the 2.0 l.
Any other races if you need that low end, is the results of miss judging of the gear in that particular the turn or too early shifting. So neither is a set up caused issue.
Only reason is why in rally you need some displacement help, because you are greatly restricted, and also no power on high rpms, so you need as much engine as you can have.
In my opinion.
Old Nov 8, 2010 | 05:48 AM
Drifting Away's Avatar
Well how much W2W/Time Trial seat time do you have is the question. Power cant make up for experience and skill, I would take your setup now, get some seat time then move on to suspension mods and brake upgrades first untill you find your rhythm, then by all means if you need the extra power go that route.
Old Nov 8, 2010 | 08:08 AM
TxEvo8's Avatar
The Black will already put you into a class where you will be classified by your weight and power levels, so to be competitive in those classes, you will need MUCHO weight reduction, coilovers, slicks, EVERYTHING. IMO, 2.0 and 2.3 would need to be decided after you get everything else up to speed..
Rom
25
May 15, 2017 04:47 PM
wickedep
14
Jun 22, 2016 02:43 PM
dambikeracer
38
Mar 11, 2010 06:07 PM
Buksh
33
Jun 30, 2007 04:36 AM
Jeff_Jeske
Sep 17, 2006 06:40 PM
