RaceKern.com 2012
Old Aug 20, 2012 | 11:20 AM
  #181
WheelGap's Avatar
Originally Posted by DaveK
I ran grooved slicks.
I don't have a crew to check that stuff, so I have no clue on temps and pressures.
Depends on the year, but typically 30-40 degrees.
Dave
*****Hopefully this post did not offend the moderators of this forum. It appears that years of knowledge gained from active participation in real motorsports and understanding of safety equipment should be awarded not with some "thanks for your opinion" attitude, but rather with "you've been slapped with points from the ban hammer."*****
Dave, bless your heart, you did what you could do and it got ignored. You're a stand-up guy and you looked out for me and gave me some good advice when I started in rally and you've looked out for other competitors -- it's a personality feature, not a bug. EvoM needs MORE people like you, not less. We got plenty of cone-squishing folks on here if that's your thing; hill climb, rally & Pike's Peak experience, uh.. not so much.
Congrats on the finish, that is moving!
- Tony
Old Aug 20, 2012 | 04:35 PM
  #182
jerdeitzel's Avatar
I was a bit skeptical of grooving slicks until i saw how well they worked at MW. Good choice obviously!
I can't believe you recieved point!
Old Aug 20, 2012 | 04:46 PM
  #183
DaveK's Avatar
I wasn't able to get much heat into them at all during the practice runs (early mornings, cold air, colder ground, less than 4 miles to run), but on race day about 5 minutes after making the summit (last 2 minutes of the run on wet ground), I was really surprised to find they were still HOT.
Rob - I did do some tire temp and pressure stuff, but none of it was at the top of any runs. We tried to shoot for 32f/30r hot pressures (no idea how close we got). For tire temps, I tried waving the car back and forth for the last 3/4 mile on the way down in the middle section one morning. Took me ~2 minutes to find my crappy harborfreight infared gun and it measured a whopping 80 degrees....and yes, that's intentionally missing a 1 in front.
Dave
Old Aug 20, 2012 | 08:44 PM
  #184
EVOlutionary's Avatar
285-645-18 Continental GT-R
Dave
Dave, congrats again on your fine finish. Keep up the great work. I hope to meet you on the hill some day as a fellow competitor, but if not at least as a fan/spectator.
The tire you mentioned - none of my friends in the AX/TT have used that tire. Can you tell me your thoughts/comparisons of that tire vs. something like a DOT Hoosier A6/R6 or an RA1/NT01?
What is the overall height of that tire? For comparison, I believe a 285-30-18 A6 is about 24.9 inches tall. . .
Thanks!!
Old Aug 20, 2012 | 09:43 PM
  #185
R/TErnie's Avatar
Props to Dave for calling it like it is. If you need to get points for being brutally honest... then I guess take those points and smile.
Old Aug 21, 2012 | 09:01 AM
  #186
griceiv's Avatar
Thanks!!
the 645 in the size is the height in mm. so it's 25.4" tall
Old Aug 21, 2012 | 02:20 PM
  #187
GTisRule's Avatar
The 275s are a different tire from my understanding. Those are from the Sports Car Challenge series, while the ones I'm running are from the GT Cup. There was a subie running the 245 ones this year, but I don't think the driver was pushing too hard.
I'm not as familiar with the CSCC tires, but I think those are molded in the same molds as the A6 and R6 whereas the GT ones are full slicks. Another interesting thing is that the rain tires are completely different for the 275 vs 285.
Dave
They are GP tires, not DOT legal but supposedly for endurance races. I've been having a hard time finding much information on them (Bought them as takeoffs) I figured they're the same tire, but I saw the same thing as you on Continental's site, 275's listed differently than the 285's. I just don't know if those are 'my' tires or not...
Old Aug 21, 2012 | 02:31 PM
  #188
DaveK's Avatar
Sounds good! Just promise to re-calibrate your brain a touch so that 100% isn't in your vocabulary come race day. 100% for 156 corners is a tall order....and as a fellow multi-time competitor said to me on the summit this year: "a perfect run up this hill actually seems to involve sitting on the top and wishing you'd taken XY & Z corners faster." I looked at him for a second...thought about it and then realized...its that part about being at the top that makes it a perfect run.
I'm also a fighter - took it up with the uber mod.
Correct - the cool thing about tires measured this way is the "potential" to run different widths front and rear.
I'm not totally sure either. I was going around in circles in my head trying to figure out what to run for the race this year. In my head the A6 seemed to be the best choice, but I was worried about them going-off part way thru the run. The guys I spoke with said the GT-R was better suited for the Peak than the R6, but I'm not sure if that's because of compound temperature range, carcass strength, or some other attribute.
One thing to note is that Continental did release a new compound this year called the GT-R (for road). In 2011 there was just the GT tire, which is now called the GT-O (for oval). I don't know if they've made any changes to the offerings for the CTSC classes. Here's links for those that are curious:
GT & DP tires: http://www.continentalrace.com/downl...nical-Data.pdf
CTSC tires: http://www.continentalrace.com/downl...nical-Data.pdf
Dave
Old Aug 21, 2012 | 11:26 PM
  #189
Bueller's Avatar
Agreed with the other posts. If you got penalized for your comment we know its ridiculous. Unfortunately, by penalizing you for speaking the truth in that situation theyre only hurting Evolutionm because it trivializes the quality of this forum.
Old Nov 8, 2012 | 05:54 AM
  #190
jerdeitzel's Avatar
Congrats on winning AWD unlimited at the Global time attack/Super lap battle!
Old Nov 8, 2012 | 09:53 AM
  #191
Bueller's Avatar
Congrats Dave. I see this was yesterday? What was your fastest lap, and do you have in-car video of it?
Old Nov 9, 2012 | 02:09 PM
  #192
DaveK's Avatar
Thanks guys!
The event was on Wednesday, spent yesterday driving home, and this morning sleeping it off. I have confirmed that I've got front & rear facing video of our last (fastest) session, so I will try to get something edited up i the next few days.
As this was my first trip to the track, one quick view of my footage revealed many places to make up time. Unfortunately a suprise mechanical condition stole any free time I had and prevented me from viewing session video and data. So while not terribly happy with my driving and bummed by the fact that some of the fast guys "mechanical'd out", I'm still thrilled with the win.
Dave
Old Nov 9, 2012 | 03:38 PM
  #193
Robevo RS's Avatar
congrats Dave!!!!!
Old Nov 10, 2012 | 07:35 AM
  #194
EVOizmm's Avatar
Nice job!
I really like what those GTA guys are doing, just wish it wasnt SOO far from the rest of merica.
Old Nov 11, 2012 | 09:49 AM
  #195
killerpenguin21's Avatar
car looked awesome out on buttonwillow! congrats.
