Evo 10 crash at Beaverun
Old Nov 29, 2012 | 04:18 PM
wjamyers's Avatar
holy crap that was nearly painful to watch.
Old Nov 30, 2012 | 12:35 PM
dsmbruno's Avatar
watch this everytime you think of doing any non approved cage.... def scary to watch
Old Dec 1, 2012 | 08:27 PM
Jeff_Jeske's Avatar
I so need a cage..... I've had soo many close calls and have been simply lucky... I wonder what this would have looked like without the cage.
Old Dec 1, 2012 | 09:16 PM
honda-guy's Avatar
i spoke with him on my friend's FB wall where the video was posted, he said the car landed back on the track after the impact. i agree that he probably shouldn't have gotten out of the car that quick, considering other cars are are still going by pretty quick. he said they red flag shortly after he got out, but i'm surprise that they red flag sooner considering the car landed back on the track.
Old Dec 2, 2012 | 04:50 AM
Robevo RS's Avatar
sure you stay in the car until the safety crew comes. But that is always depends on the nature of the crash. If i got a small or easy identifiable none fire hazard crash, ill stay. But if i have a huge and smoky crash , i dont know where it comes from, since the accident just happened. So i leave asap.
I also know this is not a proper way, but **** that when you have a chance for a huge fire.
I rather leave in time, then stay in the fire if that occurs, and take a risk when i get out the get badly burned. because most of the time fire comes couple sec later, and when it comes is fast and furious. Hard to see what you doing + panic + smog etc. Thanks, but i take my chances when the accident is this big, to get out as fast as i can.
I also know i shouldn't say this..... LOL
this is the crash are you referring to?
Old Dec 2, 2012 | 06:41 AM
honda-guy's Avatar
^ that's true. but if the car crash because of fluids on the track, that means that other cars will hit the same fluid and head in the same direction and crash into you. and i've seen that happens more often then cars catching on fire on track. we can discuss what we should or could do, but until we are put in that situation, we're not going to know how we'll react.
Old Dec 2, 2012 | 06:54 AM
ezzey's Avatar
Im a little confused as to what exactly happend for him to just go straight like that? Front tire lifted before turn? Anyone know/care to explain?
And that was a brutal hit. Glad the driver had gear and cage was properly built.
Old Dec 2, 2012 | 06:56 AM
honda-guy's Avatar
^ the front driver side tire had a huge cut and the tire went down and came off the rim.
there's another video that shows telemetry but i can't find it, he might have took it down.
Old Dec 2, 2012 | 08:01 AM
jerdeitzel's Avatar
The key is that you should not leave the car until the track is secure from race control. Since i hear corner workers talking in the background i will say that the corner workers were on scene and the track was under caution. At that time you may leave your car and head to safety if instructed to do so or if you have at least made eye contact with the corrner worker and they are not telling you to stay seated.
Old Dec 2, 2012 | 08:13 AM
Robevo RS's Avatar
Jeremy I a had a roll over once, not this big but it was a ride for sure. After that , I didn't even know where I came from, never mind try to get an eye contact with a workers .
But you are 100% right everyone should stay in the car until the workers get there. That is a rule and a proper way to act.
Old Dec 2, 2012 | 10:55 AM
211Ratsbud's Avatar
Probably my last words too before I hit the wall.
Old Dec 2, 2012 | 11:29 AM
Raptord's Avatar
Read the video description
Old Dec 2, 2012 | 05:50 PM
apex electric's Avatar
They call it fight or flight. It's not possible to have one rule fit all possible situations. A humans first instinct is to get away from danger. Yes if you have a mechanical brake down or graze a barrier it's easy to think clearly and follow the rule to stay put until a worker arrives and signals you to get out. It's another when you just had a hard hit amd your actions are instintual not learned and repeated.
Old Dec 3, 2012 | 08:35 AM
goforwand's Avatar
Good example of why you should keep your visor down while on track...shards of broken plastic projectiles as well as external debris can do a number on your face and (God forbid) your eyes....
Dangerous turn, regardless of mechanical error.
Old Dec 3, 2012 | 01:14 PM
Robevo RS's Avatar
Or put a clear window tint vynl on the front windshield
