Relocating the ACD Pump
Old Dec 26, 2012 | 04:33 PM
EVOizmm's Avatar
Seems pretty easy to do, and moves weight off the heaviest corner.
The ACD line is about 15 feet long. Shortening the ACD line shouldn’t cause any problems would it?
Does the ACD pump generate a lot of heat? Its stock location sees plenty of cool air. I'll be placing the pump in the right-rear. Do I run cooling ducts?
Just wondering if anyone has gone through this and what issues they have ran into?
Old Dec 26, 2012 | 08:02 PM
Raptord's Avatar
AFAIK it doesn't generate any heat.
Old Dec 27, 2012 | 04:52 AM
mouseIX's Avatar
Just curious, have you weighted it?
Old Dec 27, 2012 | 06:55 AM
EVOizmm's Avatar
I plan to take various temps of the pump at my spring testing day and see how much heat it generates. I'd assume it makes at least a little heat, and I'd assume that’s why they placed the ACD pump up front. Why would Mitsubishi not have put the pump in the trunk?
The pump by itself with fluid is probably about 15lbs. The brackets that hold the ACD are maybe 5lbs at most and can be tossed in the garbage. The only scales I have are my corner weighting scales and I borrowed them out this last weekend. I'll get some exact weights soon.
Old Dec 27, 2012 | 08:12 AM
KevinD's Avatar
the evo X and the euro evos all have the acd pump in the rear. its not going to generate enough heat to cause any problems.
Old Dec 27, 2012 | 08:46 AM
EVOizmm's Avatar
^ Thats good to know. Thanks!
Old Dec 28, 2012 | 05:08 AM
honda-guy's Avatar
check out R/TErnie ACD relocation pics. he did a really good job
https://www.evolutionm.net/forums/al...4-efr7670.html
Old Jan 4, 2013 | 08:37 AM
Meathooker's Avatar
^ thanks for posting.
i didnt see where RT got the mounting bracket and what lines he used. can anyone post those up?
Old Jan 4, 2013 | 11:06 AM
mr matt's Avatar
Yep, jdm and uk cars (ct9a) have the acd pump rear left underneath the car. If you didn't want to make a bracket, sure you could buy a uk spec oem one. Assuming the pump is the same? Ours run ayc rear diffs as standard, and have 3 outlets( I think) I blanked two to run a rs diff and keep acd.
Old Jan 5, 2013 | 04:35 AM
apex electric's Avatar
Changing the length of the power steering lines effects the steering response so the length of the ACD lines could do the same.
Old Jan 5, 2013 | 12:04 PM
todd6027's Avatar
As said above jdm /edm evos have the pump bolted to left hand side rear chassis leg and its piped from there so it wont be an issue
Old Jan 6, 2013 | 08:03 AM
EVOizmm's Avatar
Power steering is a full looped system. the ACD is not. The ACD would work more like your brakes do.
Old Jan 6, 2013 | 09:48 AM
killerpenguin21's Avatar
if you look at R/T's thread, youll see that the length of the stock acd lines is ridiculous, it snakes all over the engine bay if i recall. it appeared that running a straight line to the back of the car was, in all honesty, not much longer than the stock lines.
Old Jan 6, 2013 | 05:52 PM
EVOizmm's Avatar
Stock line is about 15ft long. My new line is much shorter.
Old Jan 12, 2013 | 03:27 PM
flyingscot's Avatar
i just relocated mine too.........its now permanently on the shelf in my garage
