BFG R1-S Test and Tune
Old Aug 20, 2013 | 02:41 PM
  #151
RJones's Avatar
Some people think that. Others (including myself) disagree.
Old Aug 20, 2013 | 04:17 PM
  #152
FilthyEvo's Avatar
I have a scrubbed in set of R1S's for sale. 285/30/18 - I don't have clearance.
Old Aug 20, 2013 | 05:20 PM
  #153
RJones's Avatar
You run XP. How can you say you don't "have" clearance??? You just have to make clearance. Because... Racecar
Old Aug 20, 2013 | 06:40 PM
  #154
FilthyEvo's Avatar
They're too wide! At least on 18x10.5 +15 wheels they are. 275/35 R6's fit fine on the same sized wheels.
Old Aug 20, 2013 | 06:56 PM
  #155
RJones's Avatar
I run my 285/30s on 18x10.5 +30 on stock rears (pulled like crazy) and spaced out stock front fenders
Old Aug 20, 2013 | 08:14 PM
  #156
Dallas J's Avatar
Veteran: Army
It's the +15 that's screwing you, that's an extra 15mm you need on fender clearance.
Old Aug 20, 2013 | 08:18 PM
  #157
psushoe's Avatar
Rear fenders? What are those?
Old Aug 20, 2013 | 08:37 PM
  #158
RJones's Avatar
Yeah... We all know how you feel about fenders. Talk about function > form.
Old Aug 20, 2013 | 08:39 PM
  #159
RJones's Avatar
I could've sworn he had the Voltex rear fenders, so I'd think that'd be enough for +15. +15 up front should be fine. I run +5
Old Aug 20, 2013 | 09:22 PM
  #160
killerpenguin21's Avatar
yeah, he has widebody front and rear.
Old Aug 21, 2013 | 07:01 AM
  #161
ratt_finkel's Avatar
Is that the consensus? BFGs work for Pro's but Hoosiers better for Tour?
I'm still not sure which is faster. But I can say this, for warm weather. I will choose the BFG's.
For under 80 degree weather I will take the Hoosiers.
For pro's or abrasive surfaces. I'll take the BFG's.
Old Aug 21, 2013 | 12:52 PM
  #162
03whitegsr's Avatar
Originally Posted by madmax199
On a side note, for autocross (autocross only) I like the unconventional way of not going for cross weight balance. Matching the sides LH/RH while keeping the distribution even seems to provide equal to superior performance. DG in his 'Autocross to Win' touched on the topic as a proponent of the practice... so some food for thoughts.
Maybe I'm not following, but if you balance left and right while keeping front to rear distribution even between the sides, haven't you inherently balanced cross weights as well?
Seem like simply the right way to balance a car?
I suppose you could set ride height then crank one corner up or down to cross balance the car and this would give you uneven LH/RH balance but still give a good cross weight?
Old Aug 21, 2013 | 02:35 PM
  #163
griceiv's Avatar
I think he is saying that if you have a car that is 60% nose heavy and 53% left heavy, the LF tire should have weight that matches both of those percentages on it. That process applied to all four tires does not yield equal cross weights unless the Left%=50%.
Old Aug 22, 2013 | 09:26 AM
  #164
FilthyEvo's Avatar
I do have rear over fenders, but the combo of the BFG's running wide, and the +15 offset are killing me. The fronts fit, but I haven't tested them on track obviously. If the wheels were 18x10 or 9.5 they would easily fit.
I'm just going to sell them and run A6's and R6's from now on though.
Old Aug 22, 2013 | 12:36 PM
  #165
I'm in the same boat. But I have 9.5's I can run them on. If I decide to run the car past this season I will do what I need to do to fit the 10.5's (more caster)
