ball joint boot heat shield
Old Mar 20, 2013 | 08:28 AM
Jeff_Jeske's Avatar
Thanks!
Old Mar 21, 2013 | 06:18 AM
boomn29's Avatar
If you're wrapping & heat protecting that area, be sure to cover the ABS sensors.
I always wrapped the ABS sensors in that DEI stuff. Never touched the boots (OEM); never had problems. I think the OEM's are a bit more resistant then the whitelines that I keep seeing pictures of burnt.
Old Mar 21, 2013 | 06:37 AM
honda-guy's Avatar
^ Agree. I didn't wrap the sensor it self because its close to the hub and behind the ams duct cover but I did wrap the abs wire with aluminum tape even though they didn't look like the heat had any effect on them prior wrapping them.
Old Mar 21, 2013 | 06:45 AM
JDavenport's Avatar
Originally Posted by apex electric
Stainkess steel would make a better heat sheild. Aluminum transfers heat quickly. Use the aluminum peices as templates. We utilzed the stock sheilds which have been sufficient.
What I want to know is where did you get that sweet caliper mounting bracket with ducting holes? Home grown?
Old Mar 23, 2013 | 04:07 AM
18bora's Avatar
Originally Posted by honda-guy
after burning through ball joint boots every season, i've finally got around to making some heat shields. i used some aluminum sheets i had laying around. the AMS back plate for the brake duct is a convenient place to mount the heat shield.
Nice work, where did you get the boots from?
Old Mar 24, 2013 | 06:17 PM
honda-guy's Avatar
^ i got the boots from my sponsor MPG.
honda-guy
Nov 15, 2017 06:04 PM
honda-guy
Sep 25, 2017 05:25 AM
honda-guy
Mar 20, 2017 08:17 AM
honda-guy
Apr 24, 2016 06:32 AM
honda-guy
32
Apr 8, 2016 05:51 AM
