DIY headlight duct
Old Apr 23, 2012 | 10:01 PM
honda-guy's Avatar
DIY headlight duct
i think 2.75" would have fit better but all i had sitting around was 3" and 2.5". the 3" was too large, so i used the 2.5". need to build an air box behind it next.
i did the whole thing without separating the lens from the housing. i used dremel side cutting to cut the hole. then used water to rinse out the debris. make sure you use distilled water to rinse afterward so there's no water spots.
Attached Thumbnails DIY headlight duct-dsc06940a.jpg   DIY headlight duct-dsc06956a.jpg   DIY headlight duct-dsc06965a.jpg   DIY headlight duct-dsc06975.jpg   DIY headlight duct-dsc07198a.jpg
Old Apr 23, 2012 | 10:17 PM
Alex.P's Avatar
Looks good! I like it.
Old Apr 23, 2012 | 10:37 PM
Jimmy Javelin's Avatar
Wow, thats looks really good.
How exactly did you go about making a perfect
circular cut through the headlight lens if you dont
mind me asking?
Old Apr 24, 2012 | 03:27 AM
honda-guy's Avatar
^ if you look at the headlight straight on, there's a dot on the lens at the center of each bulb. line up that dot to the center of bulb and use a marker to trace on the lens following the edge of beam housing. hope that makes sense. see the first picture.
Old Apr 24, 2012 | 10:11 PM
corbzin's Avatar
looks good man!
Old Apr 24, 2012 | 10:33 PM
unsungboxer's Avatar
Looks awesome, one of the cleanest ones ive seen. I had an idea to help it blend in more: try the duplicolor black chrome shadow to match your headlights. http://www.duplicolor.com/products/shadow/
Old Apr 24, 2012 | 10:51 PM
sujinX's Avatar
wow that is looking real good. i think im gonna have to do it now. what did u use to seal the lens and the duct? just regular sealant?
where did u get that duct piece? im assuming u fabbed it yourself? whats the angle of the pipe? sorry for the questions. it looks really clean.
Old Apr 24, 2012 | 10:58 PM
9!'clipseDOHC's Avatar
FCOTM Winner
Very clean!!! I like this mod a lot!
Old Apr 25, 2012 | 03:35 AM
honda-guy's Avatar
i was deciding if i wanted to paint it or not, but i kinda like the brush aluminum. it wouldn't be hard to paint it down the road.
as for the angle, after cutting the hole in headlight, stick the pipe through the hole and trace the around the lens. then use an aluminum sheet and bend it to the profile of the lens, not much bending cause the lens is pretty flat. then weld it to the end of the pipe, bore the inside of the aluminum sheet out after welding. then trim the edge to make the flange.
Old Sep 8, 2017 | 08:03 AM
Eric SlowEvo8's Avatar
Too bad photobucket don't work no more lol I want to do this on mine since my fogs don't work
Old Sep 10, 2017 | 02:27 PM
honda-guy's Avatar
ill try to repost the pics
Old Sep 12, 2017 | 05:16 AM
sounds good thx
Old Sep 23, 2017 | 07:33 PM
BillAce's Avatar
If love to see it too
Old Sep 24, 2017 | 08:23 PM
honda-guy's Avatar
photos have been updated
Old Sep 25, 2017 | 05:25 AM
thx looks good, ill just send u my light and have u do it lmao
honda-guy
Mar 20, 2017 08:17 AM
honda-guy
Apr 24, 2016 06:32 AM
honda-guy
32
Apr 8, 2016 05:51 AM
porsherules911
Mar 22, 2016 08:28 AM
Slyy
09+ Ralliart Show and Shine
207
Mar 13, 2016 05:17 PM
