SCCA Solo: ASP Gets one Back!
Old Apr 21, 2014 | 08:47 AM
  #46
griceiv's Avatar
Originally Posted by Vikingmoose
Well, it's been a pretty rough/frustrating start to the 2014 season. I've got 4 events under my belt and in those first 3 events I managed to spin more than the last 3 seasons combined! Partly struggling with setup on 3 year old dead A6's, partly me trying to adjust to the car. When it is pointed straight it's a complete animal!
just make sure you don't start screwing with the setup to make the car "work better" when you have crap tires.
I guess anyone who runs an Evo in SP/SM is bound to run into issues, I was just hoping for more than 4 events into the season. Unfortunately, it also puts a massive damper on the DC ProSolo next weekend. Not sure I can get it truly diagnosed and fixed in time.
Sounds like you killed the clutch (ACT puck style if i remember correctly). I'd pull the trans and get an exedy twin in there. Just make sure you take a close look at the transmission input shaft splines to make sure they're not screwed up before you put it back together. it only takes about 8 hours to change a clutch...you've got a whole week!
Old Apr 21, 2014 | 09:09 AM
  #47
Vikingmoose's Avatar
Whole week for most people = a month for me. No garage, barely passable mechanic skills, and 50-60 hours a week at work with a 1.5hr one way commute. In retrospect running an *SP car was probably not the smartest idea! LOL
PS - Clutch is an ACT HDSS street clutch (full face organic).
Old Apr 21, 2014 | 10:03 AM
  #48
Dallas J's Avatar
Veteran: Army
ASP/SM cars don't have to be un-reliable. True they aren't stock cars, but keeping on top of things and periodic inspections have kept my cars running with only 1 event ended due to failure (blew up a motor on a go kart track)
Old Apr 21, 2014 | 10:28 AM
  #49
griceiv's Avatar
sounds like a sick day (or 2) is in your future.
Old Apr 21, 2014 | 11:31 AM
  #50
MrAWD's Avatar
Originally Posted by Dallas J
If you are just planning to run dead old tires you would be better off on street tires. I can promise you the latest crop of street tires are faster than dead hoosiers by a large margin.
This above statement really depends on the state of the tires he was on. For two year old tires, if they were maintained properly, they would still have way more grip compare to the latest "street" tires.
Just finished my first event on RS3s after using old Hoosiers for a season and even though Hankooks surprised me with amount of grip they offered, they were no match to the tires I used to have (rears were 5 years old and fronts were 2 years old).
Interesting thing is that running on those tires for the stock EVO seem to be much better than running on Hoosiers, considering that everyone else had to do the same. Somehow, gap that was there next to the S2000 CRs is much smaller...if there at all...
Fedja
Old Apr 21, 2014 | 12:09 PM
  #51
ratt_finkel's Avatar
Don't mean to derail the thread. But dead r-comps are a unique beast all their own. While they may offer lower overall peak grip than fresh street tires. They still exhibit the same high slip angle and tossability they are known for. I've been fooled many times by dead tires over my 10 years of experience. It's nice to have local, consistent competition to gauge how far off your tires may be. Like Marshall said, don't make any drastic setup changes to compensate.
Sorry to hear about the car issues. Never fun and the timing is never right. Might be worth looking into some sponsorship help for this.
P.S. You said that you were having problems with spinning the car. I've found that even with an overly loose setup on the rear (before aero) that the car is incredibly easy to pitch and catch, or even predict. Point is, and I mean no offense, if your driving skills aren't up to task, then there may be something really amiss with your setup. Evo's are very forgiving on r-comps.
Old Apr 21, 2014 | 12:59 PM
  #52
Dallas J's Avatar
Veteran: Army
It also depends on the tire used. V710s just take longer to heat up when they age, but when I've had A6's fall off after 80-100 runs, they fall off severely (Same with the one set of Hankook Z214s I tried). I guess I was assuming a 2-3 year old tire would have 150+ runs on even single driving as we can get ~200+ runs each year and go through a couple sets.
I did 2 days on dead hoosiers (was away from home with nothing else to use) and got S* stomped by my usual STR street tire marker (I beat them normally of course, but by how much is one of my gauges).
Old Apr 23, 2014 | 09:14 PM
  #53
justint5387's Avatar
Does FD RX7 has a chance?
Old Apr 24, 2014 | 08:21 AM
  #54
I think so.
Old Apr 24, 2014 | 06:40 PM
  #55
Thanks to everyone who chimed in. The car is back together and I'll be able to make the DC Pro after all! Hopefully the Exedy twin disk I put will hold up Good thing I have the 300+ mile trip to break in the clutch.
I appreciate everyone's comments on setup and old tires. To be clear, I wasn't completely changing the car based on old Hoosiers, just shock and tire pressure changes mainly. But the spin issues were definitely mostly a setup issue. The car will have sticker HoHo's for the Pro and then the NJ Tour the following weekend so I'll see how the car does on fresh rubber.
FWIW, the car felt great at the event I blew the clutch, old Hoosiers and all.
Old Apr 24, 2014 | 07:34 PM
  #56
MrAWD's Avatar
That is great news Justin!! Good luck down there!
Fedja
Old Apr 25, 2014 | 07:28 AM
  #57
RJones's Avatar
Originally Posted by ratt_finkel
I think so.
He's just trolling. Don't humor him.
Old Apr 25, 2014 | 08:01 AM
  #58
Dallas J's Avatar
Veteran: Army
Im confused, is the RX7 not competitive? Its faster in Stock and SM trims but not in SP?
Old Apr 25, 2014 | 03:07 PM
  #59
According to Andy, the gearing is the issue with the FD. He thinks it doesn't have the grunt out of corners.
Old Apr 25, 2014 | 03:11 PM
  #60
RJones's Avatar
No, no, I meant Justin was just trolling (who let those STX guys in here?!). I'm sure if built right, with the right nut behind the wheel, the FD could be competitive.
