How to bolt in harnesses?
Old Jul 22, 2014 | 05:04 PM
polish_pounder's Avatar
Hey everyone,
So I got a set of takata drift III snaps for my buschur harness bar. Were do the sides bolt into? I know the one is probably were the factory seatbelt snaps in but what about the outside?
Old Jul 22, 2014 | 05:41 PM
MrEvo420's Avatar
Once installed let us know how you like the Takata drift III. I been debating if I want those or the standard Race 4pt. What made u choose the drift? If u don't mind me asking thanks. Gl with the install...
Old Jul 22, 2014 | 06:23 PM
I chose the drift because they are also certified street legal with the red button to I click the belt. And I went with the snap because my whole harnessbar/harnesses are now quick release and I will be able to remove everything in like 10 min haha
Old Jul 22, 2014 | 06:49 PM
MrEvo420's Avatar
Cool thanks for the info. I was also debating the snap vs bolt versions. I think you just helped me decide which ones I'd like. Nice choice and logic behind it. Thanks again!
Old Jul 23, 2014 | 08:51 AM
egis's Avatar
Probably you have to remove stock seat belt bolt on outside and install the bolt on takata harness.
Old Jul 23, 2014 | 10:25 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
This is a piece of safety equipment, so you need to do this right.
Take it to a race shop or contact the manufacturer for proper install instructions.
Old Jul 23, 2014 | 02:33 PM
MrEvo420's Avatar
Aren't you supposed to remove the original bolts and replace them with "eye bolts" or add their snap on kit, Or did u already try that?
http://www.takataracing.com/products/eye-bolts
http://www.takataracing.com/products...le-snap-on-kit
Old Jul 23, 2014 | 03:01 PM
Hey,
The second one for the bendable snap bracket is just for when you put the harness in a hard to reach or tight fitting location Which I may have to do :/ haha
Old Jul 23, 2014 | 03:05 PM
MrEvo420's Avatar
Originally Posted by polish_pounder
Hey,
Sorry If I'm wrong, just trying to help out lol
Old Jul 23, 2014 | 03:31 PM
No your not wrong I'm talking about were to put the bolts period
Old Jul 25, 2014 | 08:49 AM
M4Lki3r's Avatar
Veteran: Marine Corps
Normally, harnesses are either attached in stock locations (due to their tested strength and durability) or new ones are created (welded in usually).
With my Schroth harness, I used the snap-on clips for the shoulder attachment to the Buschur bar and the bolt-in buckles to mount to the stock seat belt locations. I'm not sure how to do it with snap-in clips that are sewn into the harness. Follow golgo13's suggestion and take it to a race shop.
Most likely you will end up having to use the snap on kit from Takata.
Old Jul 28, 2014 | 09:07 AM
GTABurnout's Avatar
My harness' bolt to stock locations for the lap belt on the out side. The inside goes to a custom eyebolt mounting location that bots to the same spot as the seat on the tunnel.
Old Jul 28, 2014 | 09:14 AM
nollij's Avatar
I used all eye bolts and clips for sub and waist belts. I put them in the location (or as close as possible) advised by the manufacturer's installation instructions with a stainless steel 3"x2" backing plate using Grade 8 hardware, spring washer and loctite.
The shoulder harness is wrapped around the harness bar on the roll bar.
Old Jul 28, 2014 | 01:02 PM
Used the snap kit and installed it to the stock locations from the stock belt and clip.
Old Jul 30, 2014 | 06:56 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Can you take pics of it installed?
This appeals to both my "I want a Schroth ASM harness" and "it's GREEN"
