Cross Weight Problem
Old Aug 22, 2014 | 10:27 AM
  #31
griceiv's Avatar
Originally Posted by white_turbo
Thanks. Will make sure I lock the steering wheel next time when I go back. For now, the plan is to replace a few things with brand new parts to eliminate the variables.
Wheel bearings
Front control arms
Unfortunately, the Evo has not seen a single autox event this year which is a bummer, but hope the car will be back in 100% for 2015.
I would not replace a single part on the car trying to chase down a 1% cross weight change. well within the range of 'normal'.
Old Aug 22, 2014 | 12:14 PM
  #32
white_turbo's Avatar
Thanks Marshall. Those two parts are not getting replaced because we want to chase down the 1%.
During the process, we found out the front wheel bearings have some play and the pillow ball bushing in the control arm is installed incorrectly (the markings are not aligned according to the FSM). So instead of having the bushing pressed out, I am just going to get a new control arm for that from the factory.
Old Sep 16, 2014 | 11:03 PM
  #33
jedibow's Avatar
Evo 8 or 9? Might be a good time to change to Evo X lower control arms if that is allowed in your class since you want to replace them anyways? Just a thought...
Old Sep 22, 2014 | 09:28 PM
  #34
Evo 9. I wasn't aware that you can use the Evo X arm on the 9. Is there any advantage to it?
UPDATE: New arms with factory bushings are in. This brought down the stiction from 1% to 0.5%. Not sure what else is sticking, but at this point, I think I will leave it as is. The car felt pretty good this weekend at Pocono, but a few more events may tell me if there is any other issue.
EvoDan2004
1959
Jun 4, 2025 12:32 PM
iD33
Apr 30, 2016 09:13 AM
SPSERG
Sep 11, 2015 10:10 AM
David Buschur
225
Dec 12, 2014 09:31 AM
Nasty Evolution
Nov 6, 2011 09:34 AM
