Blown motor
Old Apr 14, 2004 | 11:37 AM
cjb's Avatar
cjb
What's the status Wayne?
Old Apr 14, 2004 | 01:14 PM
racerferrari's Avatar
motor
well....i got the car back last friday after 3 weeks....number 1 cylinder piston was scorn....wrist pin was gone....they blamed it on the silicone form the oil pan coming off and clogging the oil return line...i don't think it was that....but hey what the hell....they did a short block ...and it runs great....i'm just glad they covered it...hopefully it makes it thru the OTC...it starts on sunday....wish me luck...thanks...wayne..www.pulpracing.com
Old Apr 14, 2004 | 01:26 PM
Guack007's Avatar
Originally posted by WINSTON
The dealer on the other hand may just replace the long block to save labor cost which might be cheaper than doing the short block, all manufacture are always looking to warranty there claims the cheapest way.
Winston
This kind of thing happend to me with warrentee work on a broken throw out bearing on my maxima 5 spd. The dealer found some metal shavings in the transmission (even though the tranny was working perfectly and I didn't mention it when I came in for the throw out bearing failure). This allowed them to just have a whole new trans-axle (clutch plus tanny) crated to them under warentee and then it was a straigh bolt and refill for them (much cheaper for labor i guess)
Old Apr 14, 2004 | 01:27 PM
siantjab's Avatar
Good luck man! Glad to hear it was warrantied; after all the bad stories floating around. Good to hear!
Old Apr 14, 2004 | 01:34 PM
SterlingEvo's Avatar
At least you had the beater Modena to fall back on in emergency ha ha ah
Old Apr 14, 2004 | 01:44 PM
mifesto's Avatar
yeah seriously, i just noticed that
Old Apr 14, 2004 | 01:46 PM
yes it was tough
yes i killed me to drive this around Huntington Beach!!! for 3 weeks
Old Apr 14, 2004 | 01:53 PM
USP45's Avatar
Is that thing pink or did the camera distort the red? Please tell me it is red, even if you have to lie about it.
Old Apr 14, 2004 | 01:57 PM
IMO, the lines of the Modena are perfect, the most beautiful car currently built. I also kind of hope that's red, unless you're a rapper... Missy E. has a lime green Murcielago
Old Apr 14, 2004 | 02:11 PM
Blak94GSX's Avatar
Originally posted by racerferrari
well they'll have the head off of the car....whats the big deal if i take the head say over to RRE and have they put a cam and gears in....that should be a quickie install with the head off of the car....i mean the dealer shouldn't have to do really any additional work....i don't think.....a guy at Buttonwillow told me that doing the cam really gave him a lot more top end
Hey Wayne,
The install is fairly quick, and although it is slightly easier to do with the timing belt alread off, it isn't all that hard to do later with the motor fully assembled.
If you wanted to, you could even do it at the track on Sunday after you've turned in some hot laps or whatever to put yourself on the board.
Glad to hear the car is back on the road again. I'll be out at Vegas with Mueller's gang of monkeys.
Old Apr 14, 2004 | 02:16 PM
AWDTurbo4's Avatar
cause they make them like that, even purple
Old Apr 14, 2004 | 02:36 PM
mr. evo "m.d."'s Avatar
I have personaly seen Wayne's Ferrari... It is definatly pink! It also has a Mary Kay sticker on the back window...
Hey Wayne, this is Josh. Doug says hi also...
Old Apr 14, 2004 | 02:53 PM
yes guys i had my car repainted gay gay HOT PINK....not!!!...it was just really sunny that day in front of my house..and it came out pink...oh well....hey Josh...i guess i'd better not talk **** about you on here....your keeping an eye on me...lol....oh by the way...the service guys are the best in the world at HB Mitsubishi!!!...
Old Apr 15, 2004 | 01:16 AM
Blak94GSX's Avatar
Actually putting cams on at this stage in the game would be a bad idea since I don't believe you have any way to adjust the fuel output to compensate for the cams.
For what you are doing with the car at the OTC the stock cams will be good anyway. Gives you nice midrange usable power.
If it is detonating and blowing up pistons/rings already, you don't need to make the fuel curve worse.
Just my 2 cents...
Old Apr 15, 2004 | 02:00 AM
mitsumichael7's Avatar
what i am saying is that they'll have the head off the car....i could send it out and purchase a cam and cam gears and have somebody install it and then have the dealer put it back on the car when the put it all back together...is the cam and gears an easy install?..how long would it take?...cam and gears arn't big bucks are they?
you can also plan on a fat VOID of the warranty that just saved your car to begin with!!
6spdlegend
Feb 23, 2017 11:18 AM
STIU2SLO
Aug 12, 2015 07:25 AM
tianma_evo
Jan 28, 2010 08:08 PM
Jspec EVO VIII
72
Jul 7, 2008 09:12 PM
blaze_125
17
Apr 14, 2006 07:22 AM
