has anyone successfully passed MRLS's 91db limit?
i run a catless, full 3" BR exhaust, so obviously i won't be passing. i'm hoping to have a "bolt-on" option for MRLS, other than just putting the stock exhaust back on.
has anyone has any luck building an exhaust that makes "okay" power (i don't need a ton) but still meets the sound limits?
all the search results i get have people theorizing, but nobody with a definite answer.
I'll look into that option, thanks. Also hoping to modify mine to work. Thinking about flanging the muffler along with my two resonators. Maybe I can bolt on a quiet muffler.
I run their stealth exhaust with no cat and it very quiet, no one ever complains and from what I have seen they still make as much or even more power than some of those louder straight pipe exhaust out there.
Am I supposed to know this clown?
Straight 3" with just the muffler and you passed? That makes me feel much better.
I cant speak for MRL, but Lime Rock Park has an 89db limit, my Tomei Expreme TI with test pipe was wayyy over the limit. We went with a catted AMS pipe and installed a Vibrant mini muffler in it. Works like a charm, still sounds good and the best part is; no more drone when I do drive her on the street.
According to the rep I spoke with they now have a guy that moves around the track on an ATV and measures from different locations. Maybe I was given bad info?
MRLS... Mazda Raceway Laguna Seca. I get it lol. Our Sunday DE groups at Road Atlanta with the PCA run similar sound restrictions. I would just lift when going past the meter hahaha. At autox's I have had success with a large 90 degree turn down that I could point away from the meter. It was made out of some scrape 90 degree thin wall piping, that was just big enough to slip over my exhaust tip. I cut some slots in the slip on portion and clamped it to my exhaust tip with a large sleeve clamp.
I have the same exhaust as you.
I don't mind lifting if the meter is still stationary. If the guy moves around, I'm stuck. I'll post pics of my exhaust so far.
