Grip and oiling
Old Jun 22, 2015 | 11:03 AM
hispanicpanic's Avatar
Grip and oiling
So i have 295's on my evo and it seems i'm able to generate more grip on my ad08's than other cars with R comps in smaller tire sizes. This starts to make me question the capability of my oiling system. I've got 3 track weekends on these 295's and i guess my question is, at what level of grip is it necessary to upgrade your oiling system from the stock setup? I know MAP is releasing a baffled pan, and moroso i believe offers something as well.
I'm only pushing 300 wheel fwiw, so powering out of corners isn't too crazy.
Old Jun 22, 2015 | 11:08 AM
kaj's Avatar
kaj
i sent my pan to Buschur and had them put in a baffle. it's simple, but should help. other than that i did a Kiggly HLA.
that's all i've had time to do, so far, but always looking for ways to keep the engine safe.
Old Jun 22, 2015 | 11:30 AM
honda-guy's Avatar
i have tracked the evo for over 4 years on stock oil pan and hoosier rcomp tires. i have the Kiggly and notice an improvement in oil pressure during cornering.
check out this post.
https://www.evolutionm.net/forums/mo...-sump-pan.html
Old Jun 22, 2015 | 11:32 AM
Oh, i have an X. I probably should have clarified that
Old Jun 22, 2015 | 02:04 PM
kaj's Avatar
kaj
i'm sure they make similar products for the X?
Old Jun 22, 2015 | 02:16 PM
killerpenguin21's Avatar
the buschur pan is not designed for road racing. there has been mention of maybe a 5psi increase in oil pressure during cornering. i bought one, did some tests with water...and then sold it. if you look at it the baffling is all in the acceleration axis of force.
Old Jun 22, 2015 | 02:21 PM
kaj's Avatar
kaj
I don't know, I'll have to look closer. I just saw a circle welded to the bottom LOL
I run a 255 tire with 140tw, but I do worry about Riverside turn at BW and nearly all of Willow Springs.
Old Jun 22, 2015 | 07:43 PM
With a 255 tire, i would hardly worry about oil starvation. But my only experience is in an X, so...... To reiterate, my 180 tw 295 section width tires are exceeding corner speeds of fully built e92 M3's on 275 Rcomps, Spec honda hatches on 225 slicks, and most porches that don't run slicks. I've had instructors ask me what tire i run, and when i tell them its not a slick they don't believe me. I havn't had a single rider yet say something about the grip levels of my evo. And it just occured to me recently that i might really be F'ing myself on oiling and i don't even know it.
Old Jun 22, 2015 | 08:15 PM
kaj's Avatar
kaj
Those are some strangely fancy tires you have there. What are they? They sure sound better than any other tire I've heard of. I need some.
Old Jun 22, 2015 | 09:14 PM
ReidFletcher's Avatar
Accusump is always an option.
Old Jun 23, 2015 | 07:44 AM
Balrok's Avatar
Yes RaceFab makes the pan for the 10's as well as evo 1-6's.
In reality the only way you'll know is if you start logging oil pressure.
Old Jun 24, 2015 | 10:27 AM
Dallas J's Avatar
Veteran: Army
I only have empirical data for my car, but 2.3 w/o balance shafts, ported oil filter housing and softer spring, kiggly hla, and 1/2qt extra fluid.
On track with 275 RA-1s my pressure (gauge watched) doesn't have any drop on right hand corners (it was the long corners I was able to watch on). Riding shotgun in my car at AutoX with 285 hoosier A6s, pressure follows RPM without dropping from starvation at any point.
That's not to say there isn't a circumstance that my car would oil starve, but so far I haven't found it.
Th
Old Jun 24, 2015 | 12:55 PM
kaj's Avatar
kaj
Silly question, I know...but
1/2 quart of oil from the mid point on the dipstick or the top reading?
Old Jun 24, 2015 | 01:15 PM
Dallas J's Avatar
Veteran: Army
We put in about 5qts in a normal change. Its right around or slightly over the max mark IIRC.
Old Jun 24, 2015 | 01:35 PM
RJones's Avatar
Hmm...before I got the Accusump, I was using between 5.5 and 6qts and I still starved in a right hander and vented the block. That was with completely stock oiling on a 2.3. Now I have a 3qt Accusump, so oil changes are about 9qts.
