What clutch is on your track car?
Per the picture, it does appear to have cracked...lol. That's pretty serious stuff. A bit scary to think it was probably about ready to frag if you hadn't pulled the motor for that rod bearing and caught it..
Yea, it's just the cover that different. The HD has a higher clamping force.
Had an ACT HDSS and eventually replaced it with an XTSS. So far 3 years of abuse on the XTSS and doesn't lock me out at autox cause 2nd is short shifted and tracks are slow shifted. Could see having issues drag racing but that's not a concern of mine.
The HDSS didn't fail. I replaced the disc just because when I had the trans out after 2nd year of use. Well through heat cycles everything wears and deforms in a similar fashion and a new disc was not. So I had it wear on only the outer inch and it slipped pretty bad.
I don't beat on the car as hard as others, Pro's I shoot for 1.7-1.8 60fts cause I give a generous rollout before dropping the clutch.
