Evo X front brake swap for Evo 8/9
#466
I may do the Crows event first weekend of August. I'll definitely be out of my element, but I've never done one, so I figure I may as well.
I guess I'll have to class my car ,though. For our events I arbitrarily pick XP to keep the locals from complaining LOL
#467
Lol I was thinking the same thing. Considering I've boiled my fluid during an autox in the past, partly my fault since my pads were thinner than ideal, but regardless you can build up some heat for sure even though speeds arent as high as on track. But as Dallas said youre not getting the same airflow.
What part of the caliper is rubbing? Is it the crossover tube; I cant picture right now what sticks out the most? Losing brakes is no fun so Im not sure how I'd feel about that knowing my calipers are rubbing on the wheel. It just seems like youre asking for trouble.
See this images from my old post. It only touched at the furthest points of the front of the caliper (top and bottom) in one little area, not across the entire caliper either. https://www.evolutionm.net/forums/showpost.php?p=11769386&postcount=72
#470
To tell the truth, I haven't looked over the rule book in years. A local guy told me to run OSP (A class that only our local chapter runs, I guess....?) but, though they show it on the class schedule each event, it's gone from the MotorSportReg.. so now I just do XP.
I have an aftermarket air filter, O2 housing, and TBE. Also cams and a fuel pump. Interior is gone except for dash, center consoles, and passenger seat. I have coilovers and camber plates. Also adjustable sway bar end links with RSB. Then tuned on e85. Perrin PSRS. I think that's it. The car is pretty simple. Oh, and a wing.
I get lost in that rule book, to tell the truth. I won't really be trying to win a class out there, anyway... so I'm not too worried about where they put me. I tend to just see how fast I can go and compare to friends. Well.. I have a friend that wins championships all the time. I don't compare myself to him LOL
#471
So XP or OPS is probably the right place specifically because of the lack of interior. SM requires full interior minus rear seats but you get to update/backdate so in the Evo's case we get to pull all sound deadening. Thats based on the RS not having it regardless if you bought an SSL.
#472
That's okay, though. I'm only there to hang out with my buds.
#473
SCCA has some stupid rules for sure when it comes to solo classings. Lack of carpet in the front cabin area of your interior (excluding the rear that is) puts you into the Prepared classes, which is so lame. I would just run it as SM and if anyone actually protests you, tell them they are a *****.
#474
#475
Id argue, why do you think you need to pull the carpet especially in a class with "street" in its name? I know the class isnt street-able in reality, but it should at least look the part of being streetable. Compare my car to Zacks FP evo and its a huge difference once you make that next step.
So while there certainly are things I would change, gutted cars in SM isn't one of the things I'd want added.
#476
#477
Many people build their car for other purposes besides driving 40 seconds at a time. There is nothing streetable about many of these SM cars at autox that come fully trailored on R comps to an event even if they have a full interior. Pushing someone out of a class based on 10 lbs of interior carpet is just silly.
Kind of like how the roll center kits aren't allowed in SP, because allowing geometry changes would allow for a snow ball of custom suspension parts and then it would basically be SM with a bit less power.
#478
There will always be particular cars that benefit from a certain mod or have an easy rule breaking mod they could do, but to the SCCAs defense, that can easily snowball on other chassis. And I can guarantee, your lack of carpet isn't making you faster
