X BBS rims with r-comps & 3-way coils
Hey,
I understand the BBS oem rim is good for the track, but what about using r-comps (Goodrich R1s hard) and 3-way suspension? Does anyone has tried it?
Thanks,
Thanks,
You can put a 245/40r18 slick/r-comp tire on that wheel and it will do fine.
Im not sure I even understand the question. Yes, those wheels will work fine with R-comp tires assuming the sizes match up. What kind of racing do you plan to do with the car? An R1S isnt going to last very long on track at all relative to say an R1.
As for the suspension combination 3 way is fine but depending on your skill level and suspension knowledge 3 way may not be a good fit for you. For starters a bazillion levels of adjustment does you know good if all the setting are crap. Don't get caught up in marketing hype. Typically a 3 way coilover will be much higher end so sure it's most likely capable of performing well but then you need to know how to dial it in. All the fine tuning does you no good if you aren't familiar with racing or suspension tuning to know what to change given what you're experiencing with the vehicle.
For starters more info as to the type of racing you'll be doing as well as level of experience would be great. From there we can give you feedback on which tires to look into and from there what suspension spring rates alignment specs etc.
- Spring rate TBD, on the street for a new suspension system. Probably 14/12. I have a separate thread on this
- I have already bought 245 40 18 Goodrich R1 (hard)
- heel2toe: I'm planning on doing time attack and clubracing. I'm heavily involved in rallying, meaning I have ample access to expert hands. Actually, a 3-way suspension for 5k is not motorsport level, just one notch below, but I'm not into "actual racing"
- MinusPrevious, can you explain me why ppl go wide? Shouldn't all the benefits of wide can be obtained with a good suspension? I'm talking for an evo under 500 whp
Thanks everyone for your input
What year EvO? You may have those rates backwards. Should be 12K/14K
I was just making a casual observation. Seemed like running a high spec 3 way coilover & R comps but handicapping w/a 8.5" wheel didnt add up to me
Why not maximize the system by running a 9.5" to 10.5" wheel that can handle those R-comps & the 3-way coilover (Also, running a 275 to 285 wide tire)
Joe
Hi Franco
Joe
Joe
Originally Posted by Franco Saval
Its a '14 gsr. Yes, typo: 12/14. There are two reason why im sticking with OEM rims. I dont want to run a hubcentric ring. I'm not going to push above 500 whp, so the additional grip is not required. Or why you think this will cripple it? r-comps are actually closer to 255. In tarmac rally, the rallyslick is 225 width
evo 10 are heavy cars. even at 300 whp, you're still going to over heat those 245 tires. you'll need all the mechanical you can get with that car. there is no such thing as too much tires for a track car. you dont need hub centric rings, if that's what holding you back from getting aftermarket wheels. i've never use hub centric rings on any aftermarket wheels and have tracked for many years. a lot of racers i know dont use them either.
i also dont spin balance my track tires
i use bubble balancer. it's good enough for track. slight vibration at certain speed sometime but it doesnt bother me when you're so focused on other things. i used to get spin balance but it would still shake after one or two track weekend. it costs me pennies to rebalance my wheels after each event with bubble balancer.
