255 vs 245 NT01 on 9.5" wheel
Old Aug 5, 2018, 07:32 AM
kaj
kaj's Avatar
I've run a 255 and it seemed a little too wide. Would a 245 work better? I'm guessing it would be the same size as a "normal" 255, but with the inconsistencies of tire sizes, who knows.
figures the 255s are cheaper, right now.
Old Aug 5, 2018, 08:46 AM
e_kobz's Avatar
255 all day!!!
Old Aug 5, 2018, 09:51 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
255 NT01 is fine on a 9.5
Old Aug 5, 2018, 10:37 AM
kaj
kaj's Avatar
Awesome. Thanks, guys.
Old Aug 5, 2018, 10:54 AM
EVO8LTW's Avatar
I just got a set of 255 NT01s. They are not particularly wide. The 255 Dunlop Star Specs that I pulled off were wider.
Old Aug 5, 2018, 12:20 PM
kaj
kaj's Avatar
Interesting. I went from R-S3 to RE71R and then Nitto, which were definitely wider. Especially compared to the Bstones. The Hankook fit perfect, the Bstones had a bit of a stretch and the Nitto fit like a NASCAR tire in comparison. I only did one event on them, though. Going right from the Bstone to Nitto, They definitely weren't as responsive... so I wanted to be sure I was running too much tire for the wheel, as I'm ordering the exact same setup. Star Specs must run crazy wide.
Old Aug 5, 2018, 12:32 PM
EVO8LTW's Avatar
When I stack the Nittos the rims hit each other and that wasn’t the case with the Dunlops.
Old Aug 5, 2018, 12:35 PM
The NT01's don't have a rim protector. That's why the wheels touch. It's def wonder than the Star spec's
Old Aug 5, 2018, 02:02 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
If you are looking for steering response from the Nittos, downsize them on the wheel. I run them in 275 on a 18x10.5 and they feel pretty good. However, they won't ever compare to the response you get from tires like the AD08R, etc.
Old Aug 5, 2018, 02:11 PM
kaj
kaj's Avatar
That was my original plan... but at my power level, running OEM brakes, etc, I decided a 255 should be okay for a while. I don't remember the 255 being horrible on the 9.5.. but it was a bit wide and I felt it really needed a 10" wheel. Since I can't fit a 10" +38 RPF on the stock trailing arms, I'm left going back to the 9.5.
I suppose I'm okay with ultimate grip vs feel for now. I remember my RS-3s being a bit on the numb side, but made up for it in other ways. I'll go the same route this time. Well, I already ordered wheels and tires, so now it is what it is
Old Aug 5, 2018, 02:45 PM
EVO8LTW's Avatar
Gotcha. Didn't think of that. I stand corrected!
Old Aug 5, 2018, 03:15 PM
kaj
kaj's Avatar
I forgot too. That strip is quite substantial, actually. I was surprised, first time I saw it in person.
Old Aug 9, 2018, 08:15 AM
King Tut's Avatar
Keep the wider tire and get a wider wheel would be my advice. Generally you want a wheel that is .5" wider than the width of the tire.
Old Aug 9, 2018, 09:08 AM
kaj
kaj's Avatar
Wider wheel won't for my car.
Old Aug 13, 2018, 07:20 AM
EVO8LTW's Avatar
I ran a Chin event at Summit Point this weekend on the NT01s and wasn’t too impressed with them. I was a few tenths slower than last time out on Star Specs of the same size, despite having more HP. I lost time mostly in the carousel due to less lateral grip, especially in turns 5-9. The tires were wider for sure because I got some rubbing on the fender lips up front. I tried 38-42 hot pressures and they were just pushy at the limit compared to my old 200tw street tires. Maybe comparing full tread depth to 2/32nds isn’t a fair comparison though.
