Evo 9 ALS strategy configuration
Old Jan 13, 2018, 02:58 PM
Fernanj2's Avatar
Unhappy Evo 9 ALS strategy configuration
Hello my Name Is Jose. I have a mitsubishi evo9. I can not activate als. never turn on ics light (water spray) could someone tell me where I can see or activate routine to activate als and spray water in my ecu with evoscan or ecu flash? Thank you
Old Jan 13, 2018, 09:03 PM
DSM*BOY's Avatar
Have you checked its getting power to the connector? Do you have a test light?
Old Jan 13, 2018, 10:27 PM
Bee-Raddd's Avatar
You want to activate the turbo antilag system? in short i dont think you really can. its there but sounds like its pretty hard to make functional. only left in for homologation purposes. Youll also significantly reduce the life of ur turbo.
You can set anti lag up on an aftermarket ecu but dont know if u can do it via evoscan/ standard ecu
As for the intercooler spray check the fuse isnt blown first. then make sure theres power to the pump and the pump isnt blown. if ur not getting the light on the dash its probably fuse. Somebody should be able to press the button manually while you check to make sure its all working.
In auto it only comes on above a certain throttle percentage and certain rpm from memory
Old Jan 14, 2018, 01:59 AM
kikiturbo's Avatar
you can run ALS with the stock ecu. First question is which E9 you have as european GSR model did not have SAS piping or the valve. It also did not have the water spray.
Old Jan 15, 2018, 11:24 AM
Fernanj2's Avatar
Unhappy Hi all, thanks for your help.
Car is a european MR type. Modified for rally race.
ecu was configured with 33mm restrictor tephra map.(are configured for ALS and intercooler water spray)but dont know how activate this funtion. Im looking for help of what nedd to make to check configuration or procedure .
with evoscan/ecuflash .
Is a used car equiped with standard ecu...
tks
​​​​​​...sorry my bad english !!!
Old Jan 15, 2018, 01:03 PM
kikiturbo's Avatar
post a picture of the engine bay
moocejuiceman
14
May 3, 2007 09:46 AM
Quick Reply: Evo 9 ALS strategy configuration
