Tyre width more is better ?
Old Feb 4, 2018 | 04:48 AM
leecavturbo's Avatar
What is the General concensus on this?
And are 17" better than 18"?
Is there a tread with what tyre size will fit evo 9?
Thanks
Old Feb 4, 2018 | 05:12 AM
If you have fitment questions, we tackle those here:
https://www.evolutionm.net/forums/ev...s-go-here.html
My CT9A is fully cleared for 275/40/17's
BTW, most hard core track guys, here, seem to run 18's
Cheers
Old Feb 5, 2018 | 08:58 AM
Driv200's Avatar
Most run 18’s for BBK’s and more tire options. My old school teaching was keep rotating weight down and my car is dialed in on 17’s. 17x10 on 295/35. Who cares I can’t stop. I just keep turning. ��
Old Feb 5, 2018 | 12:50 PM
Dallas J's Avatar
Veteran: Army
Maybe the track guys run less spring than the AX guys in general, but I like the 18s specifically because they have shorter/stiffer sidewalls. It just translate into tire being less under damped spring in the system.
As far as width goes, 285-295 is a good place for Evos. 315s require certain sacrifices to geometry (tires have to go out, inside already limited) and tire height. Im on 295s now but will switch back to 285s once these are burned out to get the car lower. 295 to 285 is 1/2" shorter tire which means car moves down 1/4", and I can lower car another 1/4".
Old Feb 5, 2018 | 02:41 PM
kyoo's Avatar
i went 18s to clear brakes. hoping the weight penalty isn't too obvious and the car handles well with the additional 10mm (265) and shorter sidewalls
SLOW2.0
26
May 30, 2013 01:55 PM
Boltz.
19
May 28, 2011 06:13 AM
diyath
Jul 10, 2002 02:57 PM
diyath
Jan 7, 2002 12:11 PM
