4g63
4g63
Hi! We run a Mitsubishi Eclipse V6 3.0L in road racing under SCCA STU rules. We are considering an engine swap to the turbo 2.0L 4G63 Evo engine. We would need to have a 35mm (1.4”) restrictor plate. Anyone know if that would make sense or how much would that plate impact performance?
35mm restrictor as a pretty big effect on power up top. WannabeGTS (I think thats his name here, Zach at PRE) has an FP Evo with a restrictor and might be able to give more info on the limits. I recall SCCA use to run something like a 37mm but had to increase it because that was too aggressive.
gr N cars used to run 32 mm which limits them to about 260 or so hp.. my guess is that with a good 35mm setup you are looking at 350 hp or so..
hybrids14
Mar 19, 2007 01:06 PM
