Maintenance Schedule for Track Driven Evos
Old Jun 6, 2018 | 09:36 AM
Biggiesacks's Avatar
Yeah, the brand name is Nitrogen. All high end racers use the Nitrogen as it is less prone to pressure deviation. For the common tracker, its not needed
If you have a costco near you they also have nitrogen and you can just pull up and fill your tires too. I love costco. Yah it would be nitrogen, but then you would have some other additives that make it better air.
Old Jun 6, 2018 | 09:39 AM
kyoo's Avatar
is it free? don't care necessarily about the nitrogen bit, but I'm always struggling to find stations with good, free air to fill tires. may have been a joke but I climb at least 10psi if I don't touch the tires at a track day. I like to refill after they've cooled
Old Jun 6, 2018 | 09:54 AM
Dallas J's Avatar
Veteran: Army
I fill my tires with about 78% nitrogen, 21% oxygen, and a few trace other elements
Old Jun 6, 2018 | 10:06 AM
LetsGetThisDone's Avatar
No wonder you're so fast! I heard N78 is the best stuff out.
Old Jun 6, 2018 | 10:58 AM
yah its free, you just pull up in front of the bay with the air and fill away. Im pretty sure every gas station has to give you free air if your a paying customer. You just have to go in and ask them to turn it on.
Edit: That might just be a California law so YMMV
Old Jun 6, 2018 | 12:39 PM
King Tut's Avatar
Engine Oil: Twice a year
Coolant: Never, add as needed
Trans Fluid: Once a year
Tcase Fluid: Once a year
Rear Diff Fluid: Once a year
Brake Fluid: Never, bleed as needed
Clutch line: Never
ACD Fluid: Once a year
PS Fluid: Never, add if leaking
#sendit
Old Jun 6, 2018 | 02:26 PM
RazorLab's Avatar
It came after blinker fluid, so...
lol, I didn't see the blinker fluid part...
Old Jun 7, 2018 | 03:22 PM
Pal215's Avatar
Originally Posted by razorlab
Is that a joke or do you have some weird superstition?
If you don't change the air in your tires after each track event, your BBQ's propane tank will run out of gas in the middle of cooking your next ribeye steak. This is a huge problem here in San Diego. I've seen it with my own eyes and it's very sad.
Old Jun 7, 2018 | 10:34 PM
True story.
Old Jun 11, 2018 | 07:17 AM
Balrok's Avatar
Or you can fill your tires with propane.
Old Jun 11, 2018 | 10:48 AM
I prefer hydrogen, it's lighter.
Old Jun 11, 2018 | 12:22 PM
kaj's Avatar
kaj
instantly popped into my head:
Old Jun 13, 2018 | 07:20 AM
Balrok's Avatar
Imagine you could float over corners and burbs, why didn't we think of this before.
Old Jun 15, 2018 | 10:26 AM
Bee-Raddd's Avatar
Engine Oil: Every event
Coolant: Never, add as needed/ drain when need to pull radiator out. otherwise might consider it every 2nd year
Trans Fluid: every 2 events.
Tcase Fluid: twice a season (3 events then flush)
Rear Diff Fluid: same as Tcase
Brake Fluid: once a year unless it seems off. bleed every event. usually every day
Clutch line: Never unless clutch feels funny
ACD Fluid: never. doesnt do enough work to warrant changing. only flush when it needs a bleed
jomagi
Aug 18, 2010 08:55 AM
ntwaddel
May 10, 2008 12:24 PM
mikespike2
Sep 27, 2007 08:54 PM
Chamama
Oct 4, 2006 02:09 PM
neilschelly
Aug 10, 2003 12:34 AM
