Sup w/them 2026 Winter Projects?
Old Sep 25, 2020 | 07:02 PM
  #2221
Construct's Avatar
Originally Posted by ayoustin
No you don't. Mike P runs his DBW mivec 9 on a 1500. The extra outputs are just for Ign and fuel.
Weird. Haltech's own website has a separate category for the Evo 9 that only shows 2000/2500: https://www.haltech.com/product-cate...subishi/evo-9/
The Evo 8 section shows 1000/1500: https://www.haltech.com/product-cate...evo-4-5-6-7-8/
But then again they have a separate Evo 8MR section that only shows the 2000/2500, which doesn't make much sense: https://www.haltech.com/product-cate...bishi/evo-8mr/ (EDIT: Reading the fine print, looks like it's only for the JDM Evo 8 MR)
Old Sep 25, 2020 | 07:27 PM
  #2222
Construct's Avatar
I glanced through the Haltech guides for their 8 and 9 kits. The 2500 kit for the Evo 9 uses the extra outputs for the check engine light, A/C control, and EVAP purge control.
On the Evo 8 pinout, it looks like the Check Engine Light is marked as non-functional when using a 1500 (?), the A/C control uses a digital out to go to a relay, and EVAP is non-functional with a 1500.
This was a quick read so I'm surely missing something. If I was getting a Haltech setup for my IX I'd just get the 2500 kit so I could use the plug-and-play setup with full functionality.
Old Sep 25, 2020 | 08:30 PM
  #2223
Dallas J's Avatar
Veteran: Army
And I guess I dont understand why thats even necessary because the difference between the 1500 and 2500 on their comparison page is only about the drivers for 4 vs 8cyl and single or dual knock sensors. As far as I/O goes, the 2500 only has 1 extra which isnt a make or break considering we dont actually have that many sensors compared to some cars.
Old Sep 25, 2020 | 11:44 PM
  #2224
TimC909's Avatar
Originally Posted by Dallas J
Motec vs Haltech, go!
AEM is bust with their latest announcement for me so its Motec or Haltech and M130 vs M150 vs 1500 vs 2500... Too many options!
Emtron KV8 - Its becoming more and more popular and used wider in World TA over the MoTeC - Got to ask yourself the question why?
It appears it can do everything the M150 can without all the licensing (cost) restrictions.
Old Sep 25, 2020 | 11:53 PM
  #2225
TimC909's Avatar
Originally Posted by kaj
I've seriously considered that setup, just keep forgetting to research further
Regarding ALS - anybody ever considered fresh air ALS using one of those TurboSmart valves?
Old Sep 26, 2020 | 06:04 AM
  #2226
EVOFans's Avatar
Ever thought of Link G4X EVO IX plugin?
Old Sep 26, 2020 | 07:54 AM
  #2227
LetsGetThisDone's Avatar
The link is the worst ECU currently available.
Old Sep 26, 2020 | 08:51 AM
  #2228
Dallas J's Avatar
Veteran: Army
Link and Emtron are out, primarily because I want to stick with what Aaron and some other local friends know if I need support.
Old Sep 26, 2020 | 09:00 AM
  #2229
Aaron actually has talked to me about Emtron. Maybe speak with him and consider it before ruling it out.
Old Sep 26, 2020 | 11:10 AM
  #2230
alpinaturbo's Avatar
Letsgetthisdone:
Why is LINK worst ECU currently on market?
Old Sep 26, 2020 | 11:18 AM
  #2231
Emtron is very highly regarded by few tuners who do not spend time on forums, keep quiet and produce fantastic results, in UK and Australia.
Old Sep 27, 2020 | 07:42 AM
  #2232
Ayoustin's Avatar
Link is a decent solution and their customer support is fantastic but doing anything beyond engine control requires tons of DIY. They're not the easiest processor to set up.
Old Sep 27, 2020 | 11:12 AM
  #2233
Construct's Avatar
They use the extra ignition drivers as high current outputs for things like A/C control and the check engine light.
After reviewing the pinout, I'm actually confused as to why they didn't simply include a few more generic high-current outputs that weren't injector drivers. Seems like it would have made integration much easier for a lot of functions.
If you're okay with DIY modifications you could use the low-current digital outputs with a relay. I don't see any reason why the 1500 wouldn't work on a IX if you're willing to DIY the connections. Frankly I'd rather spend the extra money to use all of the plug-and-play gear and preconfigured software with their 2500 kit.
Old Sep 28, 2020 | 05:14 AM
  #2234
Ayoustin's Avatar
It depends what you're using the car for. If you're building a racecar you don't need to worry about AC, evap, intercooler sprayer or MAF stuff so that frees up room to use for other stuff.
Old Sep 28, 2020 | 12:09 PM
  #2235
Lumpy Sticks's Avatar
5 Year Member
We use Emtron all the time (and I am a dealer for them). I consider them a step below Motec. They pretty much do everything the Motec does but you dont have to pay to unlock everything. They are trying to get me to ditch my AEM and go Emtron but for what I do, the AEM is just fine.
