Old Jan 26, 2021 | 07:17 PM
  #2836
kyoo's Avatar
Originally Posted by Dallas J
Finally got a response from Vivid and they said its now pushed back another month to 2/26. So MFG is just giving numbers at that point and will probably slip further. Canceling with them and sent Evasive an email to see if they have it in stock and yours wasnt the last.
if it was, ping me. i can wait until march or april when my seats come in, these brackets are gonna sit until then. if you're willing to cover shipping and you're in a rush i can send you these and you have yours shipped to me.
Old Jan 27, 2021 | 07:54 AM
  #2837
Dallas J's Avatar
Veteran: Army
Thank dude. Evasive got back super quick saying they had them in stock so now I just gotta wait for Vivid to process my refund. Would hate to have them randomly ship something cause I asked to cancel and then Im stuck with both.
Old Jan 27, 2021 | 08:04 AM
  #2838
kyoo's Avatar
awesome, sounds good.
Old Jan 28, 2021 | 08:30 AM
  #2839
kyoo's Avatar
just got some st41s to see how they do during the track season. still got plenty of pad left on the st43s so i'll probably be mid year when i get to the new pads
Old Jan 28, 2021 | 09:08 AM
  #2840
RazorLab's Avatar
41's or 47's? 41's are just a little bit better than 43's.
The ST47's worked great on my heavy *** Evo 10 when I still had the oem brembo calipers in front. Noticeable difference from ST43's.
When I went to the Trophy calipers i had to go back down to 43's because the 47's where too much pad.
Old Jan 28, 2021 | 09:16 AM
  #2841
kyoo's Avatar
41s - i dont think i need more than that for now unless i go back to road america, which i dont wish to.
400whp, 3200lbs with evo 10 brakes in front
Old Jan 28, 2021 | 09:26 AM
  #2842
RazorLab's Avatar
Should be fine with that power and weight. I needed the 47's with 5XXwhp and 3500lbs. The 43's couldn't keep up with the stock caliper/rotor size.
Old Feb 11, 2021 | 07:48 AM
  #2843
kyoo's Avatar
do cams have a break in period at all?
Old Feb 11, 2021 | 08:42 AM
  #2844
Ayoustin's Avatar
No, just make sure they're well lubricated when installed.
Old Feb 11, 2021 | 08:50 AM
  #2845
Biggiesacks's Avatar
yep assembly lube on the cams, and don't forget to bleed the lash adjusters. I also like to line up the oil hole in the lash adjusters with the channel in the head when I re-install them. If any of your rockers are scored you should probably consider replacing them. Make sure the cam journals in the head aren't scored up too. New cam seals as well.
Only thing I would worry about is the lash adjusters getting pumped up with oil before giving it lots of RPM. It's possible it could throw a rocker if they aren't. There is a factory procedure for pumping up the adjusters if you look in the FSM.
Old Feb 11, 2021 | 10:38 AM
  #2846
kyoo's Avatar
yea to clarify, new cams, springs, lifters, and valve stem seals
Old Feb 12, 2021 | 05:48 AM
  #2847
Turtletron's Avatar
5 Year Member
Instructions that came with my S2's had me revving around up to 4000rpm for 10 minutes then said to drain the oil after 1000 miles
Old Feb 12, 2021 | 07:41 AM
  #2848
kyoo's Avatar
for 10 minutes straight? i guess maybe just a highway drive in 5th then?
Old Feb 12, 2021 | 12:03 PM
  #2849
Balrok's Avatar
Any of you that have quick access to your 8/9 - whats the center hub to hub Length of the car? Or at least contact patch outsides if it's on the ground.
Old Feb 12, 2021 | 12:27 PM
  #2850
