View Poll Results: What wheel would perform "better"?
18x10.5" NTO3+M (21 pounds per wheel)
80.00%
18x10" TC105X (18.XX pounds per wheel)
20.00%
Voters: 10. You may not vote on this poll
The better choice......
Old Feb 18, 2019 | 06:09 AM
LV///R's Avatar
Since this place is dead, I figured I'd try and get a discussion started.
I'm running in ASP this coming year again, with 285mm Hoosiers. Last year I ran on the 18x10.5" NT03+M wheels (seemingly the wheel of choice for ASP evos).
I still have the 18x10.5" NT03+M's. I also have a set of 18x10" TC105X's, which are about 3lbs per wheel, lighter than the NTO3M's.
If you had to choose would you take the wider, heavier wheel? Or the lighter, narrower wheel to perform better for autox?
Thanks for your insight! Poll is up as well!
Old Feb 18, 2019 | 07:45 AM
Dallas J's Avatar
Veteran: Army
The 285s really seem to like that extra 1/2" of wheel. I was in the same predicament having 10" RPF1 and 10.5" PF01 with very similar weight difference. In the end, I decided to take the extra weight for more wheel.
Old Feb 18, 2019 | 08:02 AM
Ayoustin's Avatar
Always wider. It's not apples to apples but in the miata world it's been proven with lap times that a 225 tire is faster on a 9" wheel vs an 8" wheel. Same exact wheel, only difference being width and offset.
Stretching the sidewall a hair takes some compliance out of it but gives better turn in grip.
Old Feb 19, 2019 | 06:54 AM
BigT's Avatar
NT03's all the way. I run the 10.5 with 265's on my STU car. Nexens seem to be flush. RE71r's seem to look a hair stretched. I would not want to run any less width for 285's.
Old Feb 20, 2019 | 07:12 AM
LV///R's Avatar
This is what I was definitely leaning towards, but I always had that thought in the back of my head, "Is a half inch really worth it, especially when the wheel is heavier".
Thanks for the input so far guys!
Old Feb 21, 2019 | 08:28 AM
Balrok's Avatar
It'd basically boil down to the wider heavier wheel being better for AX and the lighter narrower one being better for RR. For me the lighter one would brake better and launch out of the corner better over the duration of the race because I don't transition as quickly. I've run the 295 hoho's on a 10" wheel and they were very happy.
Old Feb 21, 2019 | 09:20 AM
Dallas J's Avatar
Veteran: Army
I suspect steering angle has a big effect on it as well.
Old Feb 22, 2019 | 11:33 AM
LetsGetThisDone's Avatar
Steering angle and the way the car changes direction. You really tend to snap the car into corners in autocross, and require very quick response from the tire in slaloms. On a road course, not so much.
