Time to make a change. Suggestions?
Make it so! How much would it cost to cut a few sets? I'd like to use them for all four points on our cars. If possible, I'd like a couple extra sets in case someone ****s up my set
I can't afford hub stands yet, I lost access to an alignment machine, I've literally tried every single alignment shop in my town.. even a "customs" shop that charged me almost $200. I'm famous with my friends for never having an alignment done right, even by people that do their cars and they highly recommend. I'm just ****ing cursed.
kaj (Jul 1, 2019)
Aaaaaanyway, I've seen the string method. That would get me by to at least fix my toe and thrust angle. My camber *should* be spot on. I'm not sure how my toe got so thrown out of whack seeing how I believe the tow truck driver used the lower arms to tie the car down. Unless it's off too, but the alignment shop didn't get that far. I don't even know any more.
Just keep refining your string method and call it a day. Ive done it now at least 100 times (been doing it for 15 years now) and its repeatable.
Biggest thing is to level your floor left/right but dont worry about front rear. Just need 2 milk jugs, a clear tube between them, and 1/8" floor tiles for spacers. Once level, mark the spots to put the tiles and how many.
The shop I finally found charges about 400 bucks, but they have 4 waist high stands with a car lift and the same strings we all use but on cup cars daily. Lifts make that sh*t so much easier. I have said hubstands and they're great, but also found out that the QuikJak doesn't lift the car high enough to use the stands.
Yeah.. every shop I've taken the car to ruins these bolts and washers, can't center a steering wheel, complains that my car is too low so I have to take off the bumper cover (it's 1/2" lower than stock), can't seem to dial in my rear specs, use the front strut adjustment bolts to adjust camber instead of the camber plates, the car pulls to one side or the other, I get duped into paying $180 for "life time alignment services" just to have a new manager come in and refuse to use my specs... I could go on all day This last shop had to give up after ruining the bolts. When I got into the car to drive home, I had a CEL for an ABS sensor and I smelled the clutch the whole way home. I'm so sick of trying to get an alignment on this car.
Also there are easier ways(imo) than with the string method. I just use toe plates and a combination camber/caster gauge. I believe it's made by longacre.
https://pacomotorsports.com/product/...nt-hub-stands/
I've had an identical experience in this side of the bay , the only shop I'd consider letting touch the car is Roger Krauss, but at this point I'd rather just do everything.
For better or use, I use them in the rear. My car hasn’t seen an alignment shop in 10 years. I think I worry more about alignment techs breaking stuff (been there done that) than a slightly off alignment. The track is never perfectly flat and the weight of the car is never perfectly even when in motion, not to mention the inconsistent nut behind the wheel, so is it really that important to have a super precise alignment?
