Power Steering Pump Upgrade
Yes the internal volume and fast rack ratio cause the rack to cavitate creating a hard spot in the steering on quick movements. We tried both the MR2 pump and the Vauxhaul Astra, both about 20inches from the rack and on 16v.
We ended up putting a Saturn Vue power steering unit in the steering column instead of continuing to mess around with the Electro-hydraulic.
Zack
Zack
Zack
Zack
needs a bleed still by sounds of it.
turn car on. take power steer reservoir lid off. turn hard lock to hard lock several times. should squeeze the bubble out
I was interested in this question too and found a decent answer in the Evo 7 workshop manual page 37A-2. I was going to upload a screenshot of the page but for some reason image upload is hanging up at 90% and never completes.
Here is the information from that page:
Oil Pump
OIL PUMP
The oil pump is a vane type with a fluid flow control system which functions so that the steering wheel turning effort will be reduced at low engine speeds and it will be appropriately increased at higher speeds. The following modifications have been made to Lancer EVOLUTION-VI Tommi Makinen Edition.
Oil Pump
- Type: Variable capacity type (vane pump)
- Basic discharge amount cm³/rev: 9.6
- Relief Pressure MPa: 8.3 - 9.0
- Reservoir type: Separate type
- Pressure switch: Equipped
OIL PUMP
- By increasing the basic discharge amount from 7.2 cm³/rev to 9.6 cm³/rev, the assist shortage at idle has been improved.
- By increasing the diameter of the pully shaft bearing and the pump body rigidity, the pump noise has been relieved reducing vibration occurance.
For anyone interested, I've found a US made racing power steering pump that is extremely similar in dimensions to the stock pump. Displacement is also 9.6cc/rev and can be ordered with a 6 rib pulley on it. It's rated for 10k RPM and is rebuildable, they also sell a slew of different size restrictor fittings to be able to adjust assist. New they're $400 but used pumps go for $50-150. I just need to design a bracket to make it bolt onto the 4G (and since the dimensions are similar to the stock pump it'll be relatively easy).
New OE pumps are $900-1000, and used OE seem to be going for around $300-400 I don't care to complicate my car with an electric pump, just trying to future proof my car for when the inevitable happens and my stock pump dies or better yet sell my stock pump to cover most of the cost to move to this racing pump.
that said would you trust Bar's Leak ? Man I was blown away, like everyone on Youtube lol. it fixed the annoying leak on my wife's Benz leaking at the rack. That saved me a whole lot of time and money lol
I bought one because the pics show its painted black so theres a possibility that its a reman. but what came to me is very similar to the one I got from china. I'm in no rush to install it, and I returned the BBB one.
Bars leak works great for small coolant leaks. I use this because it's all organic matter (ginger, turmeric, walnut shell). Never heard of it being used in p/s system before lol. Being that ps fluid is petrol-based, Idk how it would find areas of low pressure like in glycol-based coolant/water.
works great in radiator and metal surface leaks. It's used in many high end dealers as a temp fix.
Yeaaaa a lot of the A1/Cardone reman stuff comes spray painted black and is usually junk. BBB my company just started carrying and is a little better in quality.
