MoTeC MDC Diff Controllers - Who's Running One?
well, unpluging the pump will shut down the ayc too, making the car have both central and rear diff fully open... so yeah, in some respect worst case.. but the car really felt dead on turn in... As I said.. it is an easy experiment and you USDM guys have only ACD on e8 and 9..
What I am getting at is that the ACD is not just "open" or "closed"... it is in fact very active during the driving and will change it's state many times during every transition. You can quite easily experiment with acd maps, just need a cable and a little mod to the harness so that you can map it while it is in the car.. It is not as easy as motec but a cheap start. Also, from what I have seen in the motec article, the stock controller might work differently to the motec one. In our logs it was quite evident that it was really responsive to steering inputs and not just G sensors..
I have mapped mine mostly for slippery stuff (snow) and there it makes a great difference..
i don't know if the stock acd allows for that easily. it seems the motec would.
I dont know if you want it fully open. Its worth trying but I think there must be some inherent benefit to locking under certain yaw or accel based inputs which is exactly what the OEM ecu does. Its just not fully clear what its doing and how to adjust.
Its also unclear how attempts to induce yaw (turn in) or reduce yaw (spin control) are controlled and whats best. At this point you're just guessing. Which isnt the right thing to do. If you really want to know, you need to go collect data and form a data based opinion.
I have to pull my old logs that were done in controlled conditions but short story is that under constant lateral G, i.e. steady state cornering, the central diff is FULLY open. The moment you try to induce some yaw, i.e. when it senses steering input, it will start adjusting the ACD pressure.. I always look at the mitsubishi ACD and AYC systems not as corner grip maximising tools but rather as yaw change tools.. if you get my meaning...
John Reed Racing offers an M1 firmware for the 4G63 that also includes ACD control outputs: https://johnreedracing.com/collectio...e-jrr-evo-4g63
I don't know if it offers as much control as the dedicated MoTeC MDC. I'd rather spend ~$3K on an M130 ECU + JRR firmware than $1.5K on just a diff controller. Unless maybe the JRR version is too limited.
anyone from STL to CHI that's done this before?
