Spliiter Questions......
Old Apr 25, 2020 | 04:23 PM
  #31
kaj's Avatar
kaj
Originally Posted by ayoustin
Depending on how far back it goes will determine if you will need to do so. I offer an exhaust relief as an option on my splitters for this exact reason.
I'm waiting to confirm it goes back to the subframe. If it doesn't, I'll cancel. Not sure I want to go through all the trouble and expense if it only goes, say, to the end of the bumper cover/front of the wheel well like the APR.
If it's not what I want, then back to square one.
Originally Posted by Balrok
Need a "racefab pan" option too lol. Had to make some interesting cuts around that. .
When I measured for my pan, I made sure it didn't hang lower that OEM. Hopefully it fits. 😂
Old Apr 25, 2020 | 07:56 PM
  #32
Ayoustin's Avatar
Need a "racefab pan" option too lol. Had to make some interesting cuts around that. Also included the TRE cooler on the trans as part of the driver side "tunnel" so it gets plenty of air.
Tis the evolution lol. Started with plywood, moved to 3 or 4 versions of alumalite and now on carbon/fiberglass haha. If you find the combo shape that works realitivally well, you may want to have someone try a carbon copy just to offer that option since it's not like you need to stock them. Would give you the rounded front and other liberties as well.
I've already confirmed my design clears the Racefab pan and the TRE trans cooler plate. As for rounded front edge, it's really only needed for guys chasing podiums and records, but I do have a streamlined shape edge trim I offer for the front as an option.
Carbon is something I have a very hard time justifying. For just the price of a carbon splitter I can build someone an entire underbody aero package (splitter, barge boards, diffuser) and performance of each piece won't be much worse than if they were carbon equivalents.
Old Apr 26, 2020 | 10:19 AM
  #33
LetsGetThisDone's Avatar
If it's not what I want, then back to square one.When I measured for my pan, I made sure it didn't hang lower that OEM. Hopefully it fits. 😂
The race face fab isn't lower either. It's that it extended forward where the stock one doesn't exist.
Old Apr 26, 2020 | 12:59 PM
  #34
V.8MR's Avatar
The splitter Austin designed and we built above is for my car. I have a racefab pan and an AMS 3" turbo back. I dont have any clearance issues at all.
Old Apr 26, 2020 | 01:01 PM
  #35
V.8MR's Avatar
Same can be said regarding wheel clearance, I run 18x10.5 and a 275 NT01. No issues.
Old Apr 26, 2020 | 08:29 PM
  #36
kaj's Avatar
kaj
Gotcha. Assuming the splitter is flat and straight, I guess I didn't really think of being any kind of issue. I'll have to tackle that problem if it comes up. Hmmm....
Old Apr 26, 2020 | 10:04 PM
  #37
Ayoustin's Avatar
Getting V2 brackets cut soon. Switching from steel to a thicker aluminum and if it's not too much additional cost, some weight reduction features as well.
Old Apr 27, 2020 | 09:24 AM
  #38
Balrok's Avatar
Ya it's not the pan sticking DOWN but it's extensions to the right that ran into my tunnels, racefab puts it right against the OEM oil cooler line paths so there's literally no room to go "up in there".
Old Apr 27, 2020 | 11:12 AM
  #39
Ayoustin's Avatar
Curious as to why you have your diffusers that far backward. Normally they're in front of the wheels.
Old Apr 27, 2020 | 12:52 PM
  #40
Balrok's Avatar
Much wider not further. Voltex's arch from the outside edge of the wheel to about an inch past the racefab pan.
Old Apr 27, 2020 | 06:26 PM
  #41
Ayoustin's Avatar
I think I need a pic to understand your explanation. General rule of thumb is to position the diffuser centered on the gap between the inside of the tire and the chassis/frame.
Old Apr 27, 2020 | 06:32 PM
  #42
OX's Avatar
OX
And here I thought they were moved slightly outboard, so that cut forward wouldn't be continuous........
PATRICK B.
Feb 11, 2015 08:14 AM
DynoDude55
Sep 21, 2013 09:44 AM
miniend
Aug 26, 2009 11:53 AM
ArchieBabes
Dec 11, 2008 09:51 AM
Jungmin123
Sep 22, 2006 11:13 AM
