Flexible wire sheathing?
Old Aug 17, 2022 | 09:09 PM
211Ratsbud's Avatar
Gents,
I've found some silicone heat shrink tubing but most of it looks unreliably cheap or imported. I need to sheath in professional fashion a set of 6 conductors by 22ga, and I want it to be very flexible with no adverse strain locations ie kinks etc..
What are you using?
Old Aug 18, 2022 | 09:27 AM
ViciousLSD's Avatar
I used these a lot recently, esp when I relocated my ACD, batt, dressed up the engine bay
1/8" 1/4" 3/8" 1/2" 3/4" Expandable Wire Cable Sleeving Sheathing Braided Loom
https://www.ebay.com/itm/283736706363
1M Self-Closing Split Braided Expandable Sleeving Loom Cable Wrap Wire Sheath
https://www.ebay.com/itm/313303240107
Old Aug 18, 2022 | 09:48 AM
jarretpcurry's Avatar
I’m a fan of the DEI Easy Loom.
Old Aug 18, 2022 | 05:49 PM
211Ratsbud's Avatar
Ahh this will be exposed to the elements. I might use silicone tubing and fish the wires through..
Hrmmm
Old Aug 18, 2022 | 09:13 PM
ViciousLSD's Avatar
not sure what types of wire you used but if theyre for automotive then it can handle anything. i used the split loom on the ACD/exposed wires behind the rear wheel.
or you can use a multicore/conductor cable. I use these for my ebikes/escooters
https://www.ebay.com/itm/334487739349
Old Aug 19, 2022 | 06:12 AM
Biggiesacks's Avatar
Raychem DR-25 is the legit stuff to use. It ain't cheap though.
https://www.milspecwiring.com/DR-25-Shrink_c_325.html
Old Aug 19, 2022 | 06:48 AM
Jp7's Avatar
Jp7
I am a professional electrical engineer for a global OEM and the only thing we use on wiring like this is a heat-shrink with the glue that oozes out when it is heated and shrunk. This does a fantastic job of keeping out crusty green corrosion. As far as protection over it, I love to use the TESA brand tape over it. I bought some of this in various sizes when I re-located my battery in the evo to the trunk. I use this in all my cars and all of my connections have stayed perfect over many years of use.
Old Aug 19, 2022 | 06:57 AM
This is my favorite high level overview / intro for motorsport level wiring.
https://www.rbracing-rsr.com/wiring_ecu.html
Old Aug 19, 2022 | 08:51 AM
Balrok's Avatar
I typically use the stuff from either Summit or Pegasus. Shrink the connections and loom the whole wire from front to back. Tears up your skin though getting em in there. The "tool" only works in a straight line on a bench.
Old Aug 19, 2022 | 08:31 PM
211Ratsbud's Avatar
That is an awesome resource.
​​​​​i ordered Raytech Wonder Gel today, a Re-enterable soft silicone potting material that offers up to ip68.
Ill be digging more into the raychem stuff. Compliance will be my frenemy in this case 👍
TurboTravis
Nov 27, 2011 05:41 PM
D Grade
Northwest Region
May 17, 2011 08:28 AM
TempeRacerGuy
Jan 25, 2008 11:54 AM
TheSeige
Aug 1, 2006 04:36 PM
Red Dragon
Aug 20, 2004 11:19 PM
