help for the upcoming winter
Old Jul 30, 2008 | 05:58 PM
raiceboi697's Avatar
im looking at a car cover for my car and was wondering if anyone makes one for wingless evos?? any help guys??
Old Jul 30, 2008 | 06:17 PM
k2boarder3187's Avatar
see if you can find one for a regular lancer...that would work
Old Jul 30, 2008 | 06:22 PM
i thought the evo was a tad wider then the lancer..ill look into it thou thanks
Old Jul 30, 2008 | 07:09 PM
yes a tad, but it should still be big enough
Old Jul 30, 2008 | 08:15 PM
6-speed's Avatar
Yes there are car covers for wingless Evo's.
http://www.carcoversdirect.com/produ...TSUBISHI/2005/
Just buy the Evo RS car cover.
Old Jul 31, 2008 | 06:57 AM
thanks 6-speed?
Old Jul 31, 2008 | 07:06 AM
Marshall O's Avatar
I got mine from Autoanything.com. Covercraft Noah material. Best $200 I ever spent!!
Old Jul 31, 2008 | 11:43 AM
for the winter do i need to worry about the tires being in contact with the ground with all the snow? this is my first winter with so much snow...thanks again for the help guys i just ordered a covercraft with the noah material!!
Old Jul 31, 2008 | 01:26 PM
Bimmubishi's Avatar
You might not want to cover the car in the winter. Doing so will build moisture between the cover and the outside enviornment if you use the car every day and put it away warm.
Just let it sit outside. It'll be fine.
Old Jul 31, 2008 | 01:33 PM
well my plan is to leave her covered during the winter cause im close enough to work to run every day. any ill effects if i do it that way?
Old Aug 1, 2008 | 04:32 AM
Marshall O's Avatar
I have the cover he just bought, and it does a great job of not building up any moisture. It actually 'breathes' to avoid this. The cover itself will be soaked after a rain, but the car will be dry. I will be using this during the winter as well. Besides, if it is below freezing, there won't be any moisture anyways!
steveliu30033
Jan 8, 2017 10:04 PM
Mongo
11
Jul 24, 2007 10:19 AM
ctdragon
10
Mar 6, 2005 06:19 PM
Derek888
Feb 27, 2005 10:02 PM
