Att: SoR
Old Apr 1, 2004 | 12:00 PM
johnjonfenomeno's Avatar
Attn: All that have the Hardy 3 guage Panel
I know you also ordered the 3 guage panel from Craig. Just wondering how is the fitment on yours cuz on mine everytime i screw the plate down the top corner's pop out. Are you getting the same problem?
Old Apr 1, 2004 | 12:15 PM
blonde's Avatar
I think that a PM is much more appropriate for this. this is a specific question to a specific memeber.
i will leave it open because i know that there are other members with the same pod so maybe they can help you out.
thanks
Snir
Old Apr 1, 2004 | 01:54 PM
Pitbul09's Avatar
Mine doesnt have that problem. Thought i wish there was away it attached a little better on the top best thing to do is use some 3m tape.
Old Apr 1, 2004 | 02:30 PM
Can you depress the three climate control buttons without having them get stuck?
Old Apr 1, 2004 | 04:25 PM
Pitbul09's Avatar
yes if you cannt just hit it with a dremel or some sand paper
Old Apr 1, 2004 | 05:36 PM
SoR's Avatar
SoR
Hi... yes mine also pops up top if I press harder in the bottom and I also has the buttons problem - the hole is just too tight and I'll have to dremel or sand it a bit to get more clearance. I can't believe Scotts is a perfect fit
Anyways, I believe if it's properly tightened it wouldn't move both at the top or the bottom. I'm still to see what can be done about that. The idea of tightening it with only 2 screws in the bottom doesn't thrill me.
Unfortunately I don't have too much time to play with it and the weather doesn't server me either.
Old Apr 1, 2004 | 06:11 PM
mifesto's Avatar
its custom made, i woulda expected it..
Old Apr 2, 2004 | 07:47 AM
Problem solved guys.... I just adjusted the way I tightened the screws(not all the way in) and used the double sided tape as Scot indicated. Mounts perfectly nothing pops out and the climate control buttons are functional.
