Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Need some opinons... Safe to run Race gas..
Old Jul 7, 2006 | 05:00 PM
Turbojunkie's Avatar
like warr told ya, crank it up to 25 psi if your running straight 100 and above. as far leaded or unleaded you will never know the difference with your mods. (running leaded gas a few times is not going to hurt anything). on a flash your running probably 10.6-10.8 afr's at wot so no need to worry about runnning lean. crank it up and go have some fun.
Old Jul 7, 2006 | 05:20 PM
boostedwrx's Avatar
Originally Posted by hanahawaiian
Go North Auburn way.. in Auburn.. 76 gas station sell Trick Racing Fuel Unleaded 101 octane for $5.75.. that i recently Fill up.
If your in the area, why not just use the 94 octane for a pump gas tune? Personally, I would only waste the cash on the 101 pump if I were to be running a pure race gas map. Besides, if the tune is on, there shouldnt need to be any "knock insurance."
If anyones still interested in mixing their pump gas, check this 76 92/100 mixing chart. http://www.osbornauto.com/racing/blend.htm
Old Jul 7, 2006 | 07:16 PM
NDgsx's Avatar
Run VP C16, pull the wastegate vacuum line, pray
Just kidding.
I wouldn't recomend doing things on your own without a logger and hopefully a wideband too (I recomend spending the money up front for something with a NTK sensor. The bosch sensor is cheap to replace, but they don't have a long lifespan. Make sure you mount it straight up and far back from the turbo if you do get a bosch sensor).
There aren't any *good* loggers out there, but a regular OBDII logger for a palm will run you around $150. You can't log knock activity, but you can watch timing to see if it is being retarded as RPMs rise and for dragracing that's fine. It's hard to know for sure if it's knocking in the low end just watching timing if you're not familar with tuning though.
Old Jul 7, 2006 | 07:45 PM
boostedwrx's Avatar
yea, boost controllers are for sissies!!
Old Jul 8, 2006 | 01:40 AM
hanahawaiian's Avatar
Acutally Full 101 it help kill Turbo Lag also i dont have ECU flash yet..
I use 94 everyday.. i live spanaway area
Old Jul 8, 2006 | 01:15 PM
f-dub's Avatar
Originally Posted by voidhawk
Hi Trish, how've you been ? racegas = detonation insurance. Even without any changes to your tune, the ECU will adjust timing somewhat to take advantage of the better knock resistance. It's mostly useful for road racing where things get really hot, on drag YMMV without a specific tune.
Unless is current tune is pulling timing because of knock then the computer won't advance it. What is set in the ignition timing tables is what it goes off of, unless there is knock at which point it will retard the timing.
