Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Help Me this Weekend
Old Aug 1, 2006 | 05:47 PM
dustin03's Avatar
ok here is the run down
20g 9 5
lower ic
uego
boost gauge
egt gauge
boost control
I need some help doing this install let me know
Old Aug 1, 2006 | 05:50 PM
DahakaJR's Avatar
Where is your location, says Washington, but that's pretty vague..
Old Aug 1, 2006 | 05:51 PM
dustin03's Avatar
Bremerton you know you want to help me out I also for got to say I have cams but those can wait lol
Old Aug 1, 2006 | 05:56 PM
DahakaJR's Avatar
OMG, hehe, I would totally help you out, those are quite easy installs, just time consuming.
The problem is, I live in Longview. Which is wayyyyyyyyyyyyyyyyyyyyy down by the Oregon border.
Old Aug 1, 2006 | 05:58 PM
dustin03's Avatar
I will buy you a tank of gas and I will even fire up the BBQ
dustin03's Avatar
Plus just think you can be the frist to go for the ride in the car hope its fast well simi fast
Old Aug 1, 2006 | 06:39 PM
jd323's Avatar
I have free time friday and sunday if you need help.
Old Aug 1, 2006 | 06:48 PM
dustin03's Avatar
cool sunday is a good day for me give me a call 360-710-0138
Old Aug 1, 2006 | 06:51 PM
dustin03's Avatar
hey Danny do you have a tap set
Old Aug 1, 2006 | 07:02 PM
jd323's Avatar
I only have a standard tap and die set at the house.
Old Aug 1, 2006 | 07:03 PM
dustin03's Avatar
well I have to tap for the EGT and UEGO
Old Aug 1, 2006 | 07:11 PM
jd323's Avatar
if you need the metric set, try sears. They should have it available.
Old Aug 1, 2006 | 07:13 PM
dustin03's Avatar
well if need be I can always use more tools
Old Aug 1, 2006 | 07:38 PM
raiceboi697's Avatar
dustin use the easy way to do the EGT. pack the drill bit with grease and as you drill through the manifold the shavings will stick to the grease and not cling any where in the manifold.. i used it on mine with the turbo still attached and a few other EGT gauges i have installed
Old Aug 1, 2006 | 07:58 PM
dustin03's Avatar
it really does not matter I have to take if all the way off
