Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Friday (7-13-07) Race at pacific raceways
Old Jul 14, 2007 | 11:26 PM
  #46
Kevindanger's Avatar
John B what did you end up doing with your tranny??
Old Jul 15, 2007 | 11:58 AM
  #47
JohnBradley's Avatar
Nothing yet as the car is in the body shop getting some panels straightened after a frakking drunk side swiped it in front of my house (yes I raced it busted up anyway). I am going to fix the 6 speed and then switch to a 5 speed since I pretty much only drag race and even road racing I rather not have it in there.
JB
Old Jul 15, 2007 | 12:31 PM
  #48
hksevoix's Avatar
JB
did you ever find out who did it? +1 on conversion
Old Jul 15, 2007 | 03:56 PM
  #49
not yet, probably never will.
Old Jul 15, 2007 | 06:24 PM
  #50
hanahawaiian's Avatar
wow... i should not Drag at NIGHT!! i get alot Traction problems!
My best time is 13.1 and after is 13.5 to 14.0 cuz my 1 gear and launch and tires are spinng
Old Jul 15, 2007 | 07:17 PM
  #51
uglyevo's Avatar
thats because you need to air down your tires to 20psi for racing
Old Jul 16, 2007 | 08:12 AM
  #52
Clos23's Avatar
^ Does that go for stock tires too?
Old Jul 16, 2007 | 08:26 AM
  #53
GTisRule's Avatar
Exactly, 6 speeds arent the choice for drag racing. Jason, what did your last run end up. We left right as you guys got back to the parking lot. I managed a 17.26 @ 80 in the rental, 17.5 @ 79 with a passenger. Autos definitely launch easy though.
jb
I ran a 13.9 on the last run, shifting into 5th 25' from the trap @ 7krpm.... the second I had the clutch to the floor I remembered the 8k redline. All in all I felt there could be a solid second lower resolved from driver error.
Old Jul 16, 2007 | 08:31 AM
  #54
uglyevo's Avatar
yes
Old Jul 16, 2007 | 09:04 AM
  #55
20 psi sounds like a good number. I had the same tires as Chris and I put them to 24 psi. I was still sqeaking and not really gripping hard enought. Or it could the proxies 4.
Old Jul 16, 2007 | 12:59 PM
  #56
uglyevo's Avatar
I have been to the track 5 times this year and every time I start at 35psi and usually end up at 20psi within a couple runs
Old Jul 16, 2007 | 01:20 PM
  #57
Clos23's Avatar
Hey Duggy, my 12.3 was on stock tires and factory recommended air pressure, do you think if i deflate my tires it would help improve my 60ft? My best 60ft has been 1.73
Old Jul 16, 2007 | 01:34 PM
  #58
uglyevo's Avatar
1.73 is not too bad. It also depends on the conditions too. Since you are just learning its hard to say whether psi or driver skill would get you a 1.6 60' You just have to decide whether or not you are spinning out of the hole. 20psi also helps with wheel hop. I have never had wheel hop at 20psi but I have at 25psi and higher.
Old Jul 16, 2007 | 01:51 PM
  #59
Clos23's Avatar
Yeah, I am getting slight wheel hop, that was at 23.5psi.
Old Jul 16, 2007 | 05:42 PM
  #60
uglyevo's Avatar
I was talking about tire psi still not boost
