Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Need help - looking at getting an IX MR
Old Apr 25, 2008 | 02:23 PM
  #31
dbsears's Avatar
So was I...4th gear in the 5sp is almost the indentical to that of the 6sp. You will shift to 5th in the 5sp almost when you have too in the MR. Atleast the MR will still pull quite well with the superior 5th gear ratio.
Old Apr 25, 2008 | 02:41 PM
  #32
JohnBradley's Avatar
I made 175+ passes on my six speed. The failure was my mistake not the tranny. What happened was I was in the middle of a race and was running out of power because of the stock cams. I was already at 8k and thought if I run it out to 8300 like I usually do I am going to lose. I shifted to 5th REALLY REALLY hard and burred the slider and took out a retainer spring on 6th. I lost by .03 running an 11.54@118.7 to 11.51@122.7 (turbo Honda hatch on slicks versus my 18's).
8300 in my car with my tires and a 6 speed is 124. Now with the same tires and the 5 speed its 127.3, so it is defnitely worth doing. I have an VIII box that needs rebuilt and the IX first and input shaft. Then I will have the 1.03 4th instead of the 1.09 and be good for another 5-6mph at the same rpm.
Comes down to power and what rpm it drops off really.
Old Apr 25, 2008 | 04:01 PM
  #33
importjake00's Avatar
^^Well put.
Old Apr 25, 2008 | 04:09 PM
  #34
I forgot to add that I didnt have any gear damage at all with the power level and pass count that I have had for the last 2 years. The pictures of my gearset were around here for quite awhile but I don't think there was anything to report really. No signs of heat, no chips or burrs to report. I do not think the 6 speed is worthwhile for drag racing if you want to go really fast. I bet I could have been pretty decent with it the way it was if I had bigger cams and less drop off. Now that I have S2s and got the Green figured out I bet the 6 speed wouldnt have been quite so bad. When it gets the SMIM I know it wont be anywhere close to the top end slug it was when it made the 11.54
Old Apr 25, 2008 | 06:20 PM
  #35
aeroweenie's Avatar
Originally Posted by dbsears
^^Why not? HID's, aluminum roof, bilsteins, bbs wheels, cf accents you dont think raise the price? GL finding a nice MR for under $27k. GSR's can be had quite easily for $25k. Imo which may be the better deal depending on plans of the car. Personally I think an SE if the best evo made...have fun finding one.
You get the HID's, aluminum roof, and BBS wheels on the SE too. But I agree, MR's and SE's won't be the least expensive Evos all other things being equal.
Old Apr 25, 2008 | 07:59 PM
  #36
dbsears's Avatar
^^Hence the reason why I said I believe the SE is the best all around evo.
Old Apr 25, 2008 | 09:56 PM
  #37
AlvinHuyN's Avatar
wow this makes it much harder haha. As far as numbers goes, are the MRs made in less quantity? Im trying to find one around 300 miles here and I can't find anything at all!
Old Apr 25, 2008 | 10:15 PM
  #38
Billy@EnglishRacing's Avatar
what do you have done to your z?
Old Apr 25, 2008 | 10:44 PM
  #39
I have noticed they are more rare here also..
Old Apr 25, 2008 | 11:26 PM
  #40
codgi's Avatar
I agree somewhat. If a good deal comes across on a GSR it wouldn't be smart to pass it up. Imo I couldn't stand an RS...no power anything headlight are about as bright as my fogs and no ABS would drive me nuts. Make a good track car though. But who around here has enough $$$ to buy an evo just for a track car. 6sp may be indeed all out weaker at high hp but will all the highschool kids that now get these cars they get wrecked 90% of the time before they get the chance to dump the clutch enough times
Look carefully around the NW forum. Several people here either have them or have had them as weekend/track only cars. As soon as I sort out my condo stuff this will be track only too....
Old Apr 26, 2008 | 01:28 PM
  #41
dbsears's Avatar
^^Then they dont come to the track much because the last three times I was there was only two of us.
Old Apr 26, 2008 | 01:52 PM
  #42
No.9's Avatar
The MR shifted a lot smoother than the 5 speed I test drove, maybe better synchros?
Old Apr 26, 2008 | 05:51 PM
  #43
boostedwrx's Avatar
the 6speed on my MR is good enough for me... so far.
Old Apr 27, 2008 | 12:39 AM
  #44
codgi's Avatar
You go to every track event, which besides Auto X, includes drag and HPDE/lapping days, between PIR, PR, Bremerton and Spokane (when it was open)?
You get around man . nothere (easy current EvoM example of the above) probably hasn't seen you at a track either....
Gary and Eric who were also pretty active on this forum back in the day have sold their cars as well (Eric's old car is owned by someone in Portland who dd's a vette and pretty much only tracks that Evo too...he is on here but I forget his name....).
Old Apr 27, 2008 | 01:00 AM
  #45
AlvinHuyN's Avatar
Hey guys, do you know anywhere that will have an Evo IX in stock? I only find private sellers and some weird dealerships but it seems that the Mitsubishi dealers don't have anymore IX huh? What dealers do you guys to through for the Northwest...everything I found is closed!
