Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Service Engine Soon Light
Old Dec 29, 2008 | 05:59 PM
codgi's Avatar
Originally Posted by migs647
CEL eliminator will work. Or just get a anti-plug fouler and drill it out. Add it to your 2nd O2 Sensor.
No need to. If the car is running the stock ECU you can simply turn off this code if it really is the cat causing the problem. Much cleaner solution
Old Dec 29, 2008 | 06:01 PM
codgi's Avatar
Originally Posted by nemsin
Its from Works
http://www.worksevo.com/store/produc...roducts_id=119
I hope the code was due to the cold weather last week.
You can search around and see if other users in cold climates have the same problem. You could get the O2 sensor checked as a backup though.
